Pic:
Ive got an athlon 8x 880k and a gtx 1050 ti (Which work well together, the CPU being the slightly slower of the two)
As you can see in the pic the "Turbo Performance Boost Ratio" is disable, but the "Core Performance Boost Ratio" is put on auto.. My question is will putting the "Turbo Performance Boost Ratio" on Auto see a slight performance increase?
Thanks very much!
How about trying it out and benchmarking the CPU for us? When I see those options with a overclockable chip I'd just turn them off and overclock manually.
Desktop benching:
1 hour ago, hedghehog said:
Pic:
Thanks very much!
Yes, should do, it's almost the same as the auto overclocking for the phenom II 1055t models by the looks of it, you won't get much out of it though maybe, IIRC you can actually set the OC to 10% etc, I don't have mine handy ATM to look for you as it's at home in my attic/loft, but pretty sure.
You won't lose anything by trying anyway.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
