Reformatting Old Hard Drive
By
Littlelaner
in Storage Devices
in Storage Devices
Solved by ARikozuM,
I would grab the Windows 10 installer for USB from Microsoft.
Boot into the USB Installer.
Find the extra options.
Open Command Prompt.
"diskpart"
"List disk"
"select disk #"
"clean".
Or you can do a format like EW said from within the same installer.
Edward78 ·
Posted in Linux, macOS and Everything Not-Windows0 -
Aorammer ·
Posted in New Builds and Planning1 -
1
TunaFishnSkys ·
Posted in Power Supplies2 -
1
6
kasdashd ·
Posted in Laptops and Pre-Built Systems0 -
2
2
play_circle_filled
Latest From Linus Tech Tips:
That Time I Almost Got Sued - WAN Show April 18, 2025
play_circle_filled
Latest From ShortCircuit:
Should you buy a Gaming Tablet? - Lenovo Legion Tab Gen 3
