Black & White + Red LED Accent Ryzen $1500 Build
Rosewill ESD Anti-Static Wrist Strap Components RTK-002, Black/Yellow    $5.99
ASRock X370 TAICHI Socket AM4/AMD X370/DDR4/Quad CrossFireX & SLI/SATA3&USB3.1/M.2/Wi-Fi/A&GbE/ATX Motherboard    $224.99
AMD Ryzen 5 1600 Processor with Wraith Spire Cooler (YD1600BBAEBOX)     $219.99
ARCTIC MX-4 Thermal Compound Paste    $6.97
(Comes With CPU)    $0.00
HyperX FURY Black 16GB Kit (2x8GB) 2133MHz DDR4    $109.23
MasterBox 5 Mid-tower Computer Case    $65.30
MSI Computer GTX 1070 ARMOR 8G OCV1 NVIDIA GeForce    $374.99
Gigabyte GC-WB867D-I REV Bluetooth 4.0/Wireless AC/B/G/N Band Dual Frequency 2.4Ghz/5.8Ghz Expansion Card     $51.98
PNY CS1311 240GB 2.5" Solid State Drive     $99.99
Seagate 2TB BarraCuda SATA 6Gb/s 64MB Cache 3.5-Inch Internal Hard Drive     $66.99
EVGA 650 GQ 80+ GOLD 650W Semi-Modular Power Supply    $72.29
Asus VX238H 23.0" (1920x1080) Gaming Monitor    $139.00
Cooler Master Devastator II Wired Gaming Keyboard w/Optical Mouse    $27.27
Total    $1,464.98
I'm very happy with how this build turned out and will be ordering all the parts tomorrow. If you have any questions about the build, or would like me to make a log about all actual build process and how it runs, just let me know. Also if you have any other suggestions for me or my build, please let me know. Thanks!
https://linustechtips.com/topic/782938-black-white-red-led-accent-ryzen-1500-build/
you don't need the wrist-wrap and thermal compound, don't bother with those. X370 taichi is pretty expensive for the features you likely won't use, get the X370 killer SLI/AC instead. the taichi also comes with a wireless adaptor so don't get the WB867D-I. see if you can get a 144hz/1440p monitor with the money saved.
the wrist strap and compound im getting as just in cases. since this my first build, im a little nervous and want to be sure i have everything. Then with the tachi wifi, i read from some sources tat it isnt the best built in wifi. and in regards to the killer, while cheaper, the tachi had better reviews, plus the K in the middle kinda looks gross to me. Then for the monitor im kinda worried getting a 1440p monitor may slow my fps down possibly, but if you maybe had a monitor in mind i could take a look at it?
the wrist wrap isn't needed, to ground yourself all you have to do is remember to touch something metal before and during the building every so often. the wraith cooler included has the thermal paste already included and it's very easy to install, you won't screw up the thermal paste application unless you REALLY fuck up the installation. in either case, you shouldn't spend so much on a motherboard, you can get one that's cheaper and do just as well. the gtx 1070 is fine with running games at ultra 1440p, you can reduce a couple of settings if it can't maintain fully stable 60fps.
skip to 4:07.
skip to 4:07.
currently looking for a possibly slightly cheaper monitor, hopefully one with gsync and 1440p
try Dell S2417DG, one of the cheaper monitors with 1440p and g-sync
On 2017-5-22 at 9:43 AM, herman mcpootis said:
the wrist wrap isn't needed, to ground yourself all you have to do is remember to touch something metal before and during the building every so often. the wraith cooler included has the thermal paste already included and it's very easy to install, you won't screw up the thermal paste application unless you REALLY -fuck- flip up the installation. in either case, you shouldn't spend so much on a motherboard, you can get one that's cheaper and do just as well. the gtx 1070 is fine with running games at ultra 1440p, you can reduce a couple of settings if it can't maintain fully stable 60fps.
skip to 4:07.
Touch something metal hey, will magnet work? I am trying to find my magnetic screw
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
