So I have a Logitech M510 wireless mouse that I've been using since Christmas and about a week ago it started double-clicking off and on whenever I single-click the left mouse button. It's gotten progressively worse since then and now most of the time I click the left mouse button it registers a double-click 90% of the time rendering it almost unusable for basic use let along gaming.
I've done some googling and it looks like it's a kind of common issue with Logitch mice, has anyone here had the same issue? If so how did you fix it?
I'm currently waiting for Logitech to get back to me on my support ticket I opened as I can't seem to find the receipt for it so I can't return it to Best Buy and am looking for solutions.
https://linustechtips.com/topic/782735-logitech-mice-double-click-problem/
I have used a lot of Logitech mice, the ones I've used the most are the G500, Some random wireless one and a G502. I've never had this issue, it seems like a hardware problem to me so you should wait and see what logitech gets back to you with.
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
That's what I was thinking.
I just wanted to see how prevalent it really was since googling a problem with a product can kind of become an echo chamber since the only people who really talk about the products are those who are having problems with them lol.
The mouse switch for the left button is defective. It is a problem lots of Logitech mice have. If you are still on warranty try to get it RMAd or swapped out at the store where it got bought.
Else if the warranty is over and you know how to use a soldering Iron, do as I did with my MX, get fitting omron switches (cheap on ebay) and swap them out yourself.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
Yeah lol. Just see if you can find the receipt.
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
This is really a hugh problem Logitech has and ignores. Else there wouldn't so much tutorials on Youtube for lots of Logitech mice on how to swap out the switches.
Main System:
but yours is a g series mouse which most likely are much better built than rgular m series which is like consumer/budget type
Again, I used cheapo 20$ wireless one for like 5 years no problem. You really shouldn't be having that problem with a almost new mouse from a good manufacturer like logitech.
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
Try removing all Logitech software from your machine and go with the Microsoft defaults on the mouse.  The Logitech software caused more problems for me than it solved.  Of course, after removing the software, reboot the machine.
After removing the software, everything returned to normal including the clicks and the lines scrolled when using the wheel.  Using a Logitech Performance MX now for a long time, years.  Love the mouse, hate the software.
I've tried that already unfortunately. My first guess was some sort of driver issue but I've uninstalled/reinstalled every piece of software Logitech has and am using the default driver from Microsoft now as I didn't see the point in leaving software installed that didn't fix my problem. This is what led me to believe it was a mechanical problem and to start looking for similar issues online and it seems it affects a lot of their mice.
