I'm looking at this GPU: https://www.mindfactory.de/product_info.php/8GB-EVGA-GeForce-GTX-1070-FTW-Gaming-ACX-3-0-Aktiv-PCIe-3-0-x16--Retail_1109793.html
Now I remember that there were some problems with GTX 1070 EVGA ACX 3.0 with VRM overheating, and I would just like to check if anyone know, if that was fixed, and those GPUs are now being sold with this problem fixed?
Or should I stay away from this lineup, and buy something else instead?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
The issue wasn't VRMs overheating, it was in fact defective components that EVGA were originally supplied to build their previous GPUs. The VRMs can handle really high temps, 120º centigrade maximum.
But recently EVGA decided to go absolutely insane with cooling, like waaay overkill for the VRMs. But having cooling for the VRMs is better than having no cooling.
http://www.gamersnexus.net/guides/2691-final-evga-vrm-thermal-torture-test-and-analysis
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
There's no issue. I actually haven't even bothered to install the thermal pads I got for my card. Temps are fine.
i7-4790k | MSI Z97 GAMING-5 | Corsair Vengeance 16 GB | Samsung EVO-850 250GB SSD & WD blue 1 TB HDD | EVGA 1070 SC | Red NZXT H440 | Cooler Master G650W
Agree, GPU temps are good, even on SLAVE bios with 122% power, though anything to keep the VRMs cooler (since there is no Temp Sensor there) is ideal.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
The problem has been addressed. Any new cards purchased should have the fix.
punch in the model number of the card you are looking at here to see if the fix is indeed on it.
https://www.evga.com/thermalmod/
After I RMA'd my 1070FTW the replacement did not have the pads.
System specs:
May I ask when did you RMA it?
WD My Cloud 4TB
I didn't have the issues, but from what EVGA has told me, the fix has gone out to all major retailers.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Did you RMA it with the retailer or did you send it to EVGA directly? I helped someone with an RMA of a 1080 FTW and his had the thermal pads applied. We sent it back to EVGA directly.
You should. According to Gamers Nexus, after doing hours of testing, they can confirm that the thermal pads do indeed reduce the PCB temperature. Their testing methodology is as scientific as it gets!
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
I assume it's fixed, this is EVGA. 2 points however:
One,  EVGA is amongst the most beloved companies in the industry because their customer service is excellent. I've heard stories of peoples GPUs dying, and EVGA not only replacing them quickly, but even giving free upgrades. Worst case scenario, you have to RMA and you might get free shit.
Two, Vega is apparently coming in June. If your not in a rush, might be worth the wait, it looks promising.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
EVGA direct.
System specs:
It's true that the temperature will be lower, but not by much. Too much trouble lol
Did you read the graphs? According to their tests, the temperatures, especially the PCB backside dropped by as much as ~20º centigrade.
Installing the thermal pads should be simple, if you're careful not to damage anything on the PCB.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
Hmm that's quite a different number than what I saw from Jayztwocents. I'll look into this a bit more.
Yep because they install K-type probes in key points that are pre-calibrated with a ice bath and hot water bath, and are within +/- ~2º centigrade. They are then logged using temperature monitors.
Look at their testing methodology for the full details.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
About a month ago...
System specs:
Thanks everyone for answers. I already ordered this GPU, and if I will notice any problems, I will just request new one.
But I do think, that EVGA is smart enough, to ship fixed cards, 8 month after they realized about that problem
WD My Cloud 4TB
"problem" more like.
my card runs just fine without it. when you do get it, run the slave bios (switch right next to the power connector).
System specs:
Will do that :)
Thanks for the info.
WD My Cloud 4TB
