Simple question here. Is there a limit on how many fittings one should use in 1 combination? My concern is towards the weight they add, so if i got a lot of fittings combined on both the inlet of the graphics card and outlet, could this be too much added weight and eventually damage the card?
https://linustechtips.com/topic/780963-limit-on-too-many-fittings-in-1-combo-weight/
doubt it, tubeing will hold it
Builds:
I've seen people do builds with just fittings. I'm sure it'll be fine, unless they're made of lead. xD
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
4 hours ago, Ardox said:
I am thinking something along this. They arent screwed all the way in so don't mind that, but this is a picture of my concern. With the water and all that....
If you're using hard tubing, the tubing itself will actually provide some support to the card. If you're using soft, it'll probably sag a fair bit, but probably no more than one of the beefier air cooled cards. It might be a bit unsightly but it shouldn't damage it.
