1080 Ti FTW 3 Vs. Zotac Amp Extreme
Go to solution Solved by RadiatingLight,
No FPS difference at all. they're both the same GPU and OC'ing (manual or GPU boost) is more silicon lottery than anything else.
IMO the FTW3 is better than the AMP!
I have a FTW 3 pre-ordered, and just learned about the Zotac Amp. I don't know anything about the statistics of graphics cards other than their models (1060 is better than 1050, 1070 is better than both, etc).
What sort of FPS difference should I expect between the 1080 Ti FTW3 and the 1080 Ti Amp Extreme? I'm using a 7700k, by the way; I'm not overlocking anything.
CPU: Intel i7-7700K @ 4.8GHz || GPU: EVGA GeForce GTX 1080 Ti FTW 3 || CPU Cooler: Noctua NH-D15 (Dual Fan) || RAM: G.Skill Ripjaws V 16GB (2x8) 3200MHZ || MotherboardAsus STRIX Z270-E GAMING || Case: Fractal Design - Define R5 Titanium (Windowless) || Storage: Samsung 850 EVO 500GB, 850 EVO 1TB, Crucial MX300 1.1TB, Seagate- Barracuda 2TB || PSU: EVGA SuperNOVA G3 750W
https://linustechtips.com/topic/780682-1080-ti-ftw-3-vs-zotac-amp-extreme/
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
@RadiatingLight
Alright, awesome. I'm a huge fan of EVGA ever since I learned about them in 2004. I'm 24 now, but still prounce  EVGA 'eve-guh' just like I did when I was 11.
2 minutes ago, Cotroneo said:
'eve-guh'
*Dies of cringe*
Desktop:
Laptop:
