Hello everyone,
I'v been searching for an answer on this question for a while now. Are the Corsair vengeance RGB (CMR16GX4M2C3000C15) ram kits compatible with any ryzen motherboards? More specificly the gigabyte AX370 motherboards? Because i found some posts that said that they should work with the gigabyte RGB fusion software but i never actualy saw any actual build. I also searched the memory support list but i didn't find them on the list neighter did i saw the vengeance led modules but i have seen actual builds of those. I hope i get an answer soon so i can start ordering the parts and start building.
thanks in advance :)
https://linustechtips.com/topic/780679-ryzen-corsair-vengeance-rgb/
They should work. no guarantee they work at their rated speeds, but the RGB will work AFAIK
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
