So I have a Seagate Firecuda 2TB 2.5 hard drive in my desktop and I'm only getting read and write speeds of around 30MBps on a SATA 3 interface where as my 2 desktop drives that are in raid 0 can get up to 200MBps on a SATA 2 connection, Any ideas?
Rainbow Barf
CPU: i7-12700K GPU: RX 6800 XT RAM: 64GB DDR4 Storage: 2TB NVME SSD RAID - 1TBx2 NVME SSD - 8TB HDD
Lenovo Legion Pro 5i
CPU: i7-12700H GPU: RTX 3070 Ti RAM: 32GB DDR5 Storage: 1TB + 1TB SSDs
https://linustechtips.com/topic/776032-why-is-my-hybrid-drive-so-slow/
What are you using to test speeds?
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
crystal disk mark
Rainbow Barf
1 minute ago, Electronics Wizardy said:
Any thing else running?
Is there a os that is running on this drive. I'd try a reformat without a os.
no this is with nothing else using the drive and the drive is only used for game storage
Rainbow Barf
So apparently enabling write cache on the drive boosted read to 104MBps and Writes to 63MBps, doesn't make much sense to me but hey it works.
Rainbow Barf
Honest question: isnt that how the hybrid drive works and the benefit to it? caches most used data on the ssd and storage on the hdd?
Intel i7 6700k|Asus Maximus VIII Hero|Asus Strix 1080|Gskill DDR4 3200|950 Pro M.2|Corsair RM750|Corsair OBSIDIAN 500D|Corsair K65\G65|SteelSeries Arctis 5|Asus PB277Q|PG279Q
Yeah, it's slow the first time its sees data. Then it has SSD speeds on reoccurring transfers of that data. He'd have to run the benchmark multiple times to accurate speeds.
This should be done on the drive level and shouldn't be an option to be toggled on windows, from my understanding the windows option is for RAM caching
Rainbow Barf
