Does enabling Hardware Virtualization affect performance in any way?
Hey i got an android emulator and it says that i should enable Hardware Virtualization to gain more performance in the emulator.
My question is could enabling this affect my system's performance in a negative way?
I have an i5-6600k Overclocked to 4.5GHz with an Asus Z170A mobo.
Nope, its a separate set of features (called VT-X by Intel) and has no impact on performance outside of virtualised environments.
https://software.intel.com/en-us/blogs/2009/06/25/understanding-vt-d-intel-virtualization-technology-for-directed-io
Ignore that, it covers VT-D and not VT-X.
Main Rig:-
Server:-
No, it just allows VM's to send commands straight to the cpu instead of going through the host OS. It's a sort of side door you open. Front door is for your windows system and the back door should be shut :P
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
7 minutes ago, Stefan1024 said:
No, it's a HW feature as far as I know.
I see thanks everyone! :)
Also this is off topic but is there a way to reply to everyone without creating a giant wall of quotes?
You can tag them, for example @Amateur Gamer :P
If you dig through Group Policy there is also some Virtualization settings that are Windows based on the Software side of things. like App-V this may effect preformance as it's sometimes running as background proccess.
3 hours ago, BubblyCharizard said:
emulators like virtualbox need VT-D or VT-X enabled to have them work properly.
VT-D is an extension of VT-X.
Main Rig:-
Server:-
 Share
