Hello LTT Forums
i need some help with My new RGB build I have made 2 Builds but idk which one to choose. First Build Uses Only Asus Aura Sync. Everything is synced with Asus Aura except the Nzxt Kracken. Second Build has Nzxt hue+ and Asus Aura sync combined which Build should I choose? I left the links for PCPARTPICKER below of the builds.
basically My aim is to make all colors sync with all my hardware.
PS: Anyone can find me another set of fans for Asus Aura Sync cause the cooler master ones don't seem to be in stock ATM. I'm planing on getting this Build next mont or 2.
FULL ASUS AURA SYNC BUILD:
https://pcpartpicker.com/list/RFLR6X
What Hardware is Synced with dis Build:
Graphics Card
Motherboard
Ram
LED Strips
Fans ( Out of Stock doe )
Pretty Much Everything Just not the Cooler But the cooler is still RGB
NZXT HUE+ & Asus Aura Build
https://pcpartpicker.com/list/2hNh8K
SYNCED WITH ASUS Aura:
Motherboard
Graphics Card
Ram
SYNCED WITH NZXT CAM:
Fans
LED Strips
Cooler
The inside of me Says There's something missing from both of these builds when t comes to RGB and getting everything synced the best way possible Please Somone Tell me Which Build I should go for. And if anyone can tell me any part that's missing (MUST sync) with this build.
https://linustechtips.com/topic/768730-need-help-with-my-build/
