SO I've had my pc for the best part of 3-4 years now, and recently it's started slowing down to the point where it's barely useable. Sometimes it's okay, sometimes it isn't. Half the time everything will be fine, programs load quickly, everything works, etc, but other times itll just be ridiculous, stuttering on dragging things around, ridiculous load times for programs, chrome taking MINUTES to load webpages, freezing and crashing programs, etc etc. I've checked taskmanager during these times (takes like 3 minutes to open) nad it shows that mem and cpu usage are all below 50%, CPU and GPU are idling at a nice 30-35 degrees so it's not thermal throttling. There are no fps problems in games. Malwarebytes says everythings clear, but I dont have a normal virus scanner as avast has decided it wants to not work and refuses to scan anything. Are there any windows diagnostic tools to try and figure out a problem? Or programmes like the disk defragger to maybe help anything? Thanks in advance.
Specs:
Mobo- MSI g45 z87
CPU - i5 4670k
Ram - Corsair vengeance DDR3, 8gb,
PSU - Corsair hybrid 750W,
GPU - Galaz HOF GTX970
Storage - seagate 2tb drive (os on it) and a 500gb samsung 850 EVO
https://linustechtips.com/topic/768691-pc-slowdown-help/
You can try opening Command Prompt with Administrator rights and run the following command:
sfc/scannow
This scans for whether or not any Windows files have been tampered with and will automatically replace any with integrity violations.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/768691-pc-slowdown-help/#findComment-9704460
sfc/scannow
Alright that's running, I'll post again when it's done.
https://linustechtips.com/topic/768691-pc-slowdown-help/#findComment-9704473
sfc/scannow
Alright that reported that there was no integrity violation.
https://linustechtips.com/topic/768691-pc-slowdown-help/#findComment-9704663
