How to figure out what usb device is causing issues?
Long story short im having usb device issues and I dunno what is causing them, I got a log but im still struggling to tell what device is what.
This isnt the problem device but for example my "device name" is 0000.0014.0000.013.000.000.000.000.000
My "product ID" is 1142
But im struggling to find the name of this device (name in regards to something I can make sense of)  with googling I got a couple hits with the product id but still not common, anyone know a better way I can research what device is what?
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Unplug every USB device and try PS/2 devices and see what the issue-causing device is.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Just now, Alesek said:
unplug everything and plug it back one by one
im doing my best to avoid this since I dont want to waste my day off with a bunch of trial and error trying to figure out what the issue is, its why im trying a software solution
System Specs
idk how many usb devices you have but that cant take more than couple minutes
A lot.
And my PC is not in an ideal place for this kinda thing.
System Specs
it's not your corsair cooler is it? that's plugged into one of the USB2 headers on the board...
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
No I unplugged that thing ages ago
System Specs
3 minutes ago, Alesek said:
i still think it is easier to unplug everything.
Did you check device manager for any yellow exclamation points?
I assure you it isn't if I can find a way to look up these device names properly. If it comes to it I will but I REALLY want to avoid having to do that.
I havent looked recently no.
Edit: Just looked there is none.
System Specs
10 minutes ago, enigmakahn said:
I know your trying to avoid it, but remember step 1 of basic troubleshooting. Have your tried unplugging it and plugging it in again. It is going to be the fastest way to narrow down your search.
it might be the fastest but that's not of my concern. I would rather the physically easier route due to chronic back pain which I wish to not aggravate. I do have reasons for doing things in the way I set out to do them.
System Specs
Is the device causing any issues?
Main System: Phobos
The ones I'm currently using no. it's why speed isn't my concern, Anyways my method turned up the manufacturer which is HTC, meaning it's my vive. For some reason its doing this in standby mode.
System Specs
If it doesn't cause issues, I'd just leave it as is.
Main System: Phobos
the noise was just getting extremely aggravating its why I was trying to get to the root of it. for some reason it was doing it every 3 minutes,
System Specs
