Hi
I bought an acer predator XB321HK monitor, it says on several websites that it is overclockable to 165hz, i can not however get it to overclock at all using the nvidia control panel, any suggestions? am i missing something basic, i contacted acer "tech support" but they were useless.
Thank you
https://linustechtips.com/topic/768642-overclocking-monitor/
1 minute ago, muzza246 said:
What issue are you facing? it is very straight forwards you make a custom restolution through nvidia control panel and increase the refresh rate, and test it, if its stable nVidia will allow the card to run it...
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/768642-overclocking-monitor/#findComment-9703960
basically despite even acer saying that the monitor should be able to run at 144hz at 1440p i cant get it to overclock at all using the nvidia control panel, was hoping i might have missed something but i guess, going by that video it must be a hardware problem in the monitor
https://linustechtips.com/topic/768642-overclocking-monitor/#findComment-9703974
What is your Graphics Card and what cable are you using?
Personal Desktop":
https://linustechtips.com/topic/768642-overclocking-monitor/#findComment-9703976
its a gtx 1080 and its display port, ive tried changing the cables too just incase
Yes but I think that 1440p 144hz you need DisplayPort 1.2a the standard DisplayPort 1.2 isn't enough...
@Glenwing is a monster when comes down to monitor knowledge maybe he can see this through with you.
Personal Desktop":
https://linustechtips.com/topic/768642-overclocking-monitor/#findComment-9703985
ah ok, ill double check which cable it is, thanks a lot for your help!!
https://linustechtips.com/topic/768642-overclocking-monitor/#findComment-9703993
