So i plan on getting two monitors one for simple stuff like a video or a wikipedia page and the other for gaming and watching movies etc stuff that benefits more from 1440p. So the 1440p supports display port and the 1080p one supports HDMI can I use both. You probally can but i was just wondering. Also are the bezels and height around the same for these two monitors?
1440P:https://ca.pcpartpicker.com/product/YZn2FT/benq-monitor-gw2765ht
1080P:https://ca.pcpartpicker.com/product/mWV48d/benq-monitor-gl2460hm
Will these work together good without looking terrible?
I also plan on using both with a arm.
Just adjust the height on the GW2765HT so it's in line with the other monitor and you'll be golden. I'm dual monitoring with a 1080P ASUS and an old 1680x1050 Samsung monitor and it doesn't bother me.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
They will look just fine together as long as you don't mind the size and pixel change between the monitors. (Which wouldn't be that much of a problem if you don't plan on use both them in one program/game). Since you're planning on using an arm the height wouldn't matter that much either, but the 1440p has an adjustable stand so you'll do just fine even without the arm.
i have 3 very different ones
one normal 1080p the other is a analog (vga) but its thin and the other is a square
they are fine
