I would personally prefer the NZXT X52 as it will likely be a little quieter.
"Black Out"
Dedicated Streaming Rig
Not sure how much it will help you since i7 7700k is running pretty darn hot.
I would get X52 from NZXT since it's more quiet.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
that's the point.
My CPU is hot with a Cryorig H7, H5...
I want better temps in my life.
I need to try AIO
:( my country is hot bro, and my room is hot, 28 C and 75% humidity.
2 minutes ago, RodoGodo19 said:
that's the point.
I need to try AIO
Dubai?
WD My Cloud 4TB
1 hour ago, RodoGodo19 said:
also, I will buy 2x Corsair ml140 pro and 1x corsair ml120 pro to increase RPM inside of the case
I need to get down these temps, really.
Yeah that's all great and fun, but i7 7700k are known to run hot. You could decrease temperature by 20°C if you delid it and use liquid metal between CPU core die and IHS. But it's kinda risky if you ask me.
If you are only interested in performance, get H100i because it will give you the lowest them of those AIOs. It's as good as it gets.
WD My Cloud 4TB
do you know any good tool to delid the cpu and the link of the liquid metal on amazon?
https://www.caseking.de/der8auer-delid-die-mate-2-fsd8-019.html
That's great tool for delliding at low price.
https://www.amazon.com/Coollaboratory-Thermal-Compound-Processor-Heatsink/dp/B0039RY3MM/ref=sr_1_1?ie=UTF8&qid=1492618372&sr=8-1&keywords=coollaboratory+liquid+ultra
WD My Cloud 4TB
