Overclocked succesfully but a problem
Hey guys,
I recently overclocked my athlon II x2 260 from 3.2 ghz to 3.35 ghz. With this overclock my pc has been quite stable. It has improved the performance. Inspite of cpu being overclocked, cpu-z constantly shows core speed 3.2 ghz. Also in general settings 3.2 ghz is shown.
Is thar normal ?
well how did you verify that it actually overclocked? Could be a placebo.
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | CPU: R5 2600 | Mobo: ASRock B450M Pro4 | RAM: 16GB 2666 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
The bios exactly showed that. The processor was rated at 3.35 ghz rather than 3.2 ghz. Also, I made a guess from cpu temperatures, since I was using a stock cooler so i expected the temp to go up by 3-6℃ and temps went up.
Well what is the problem? Just a minor spout of OCD from what I can tell.
As I said, after OCing when I run cpu-z, the core speed shown is 3.2 ghz rather than 3.35 ghz. Why is this so ?
CPU-z shows only stock clocks.
Use built in CPU monitor (which you can find after pressing ctrl+shift+esc), push full load on your procesoor and then check your frequency
If you used bclk to OC your CPU you have to use sth more advenced like HWMonitor cause windows monitor won't show it
4 minutes ago, Kahir said:
If you used blck to OC your CPU you have to use sth more advenced like HWMonitor cause windows monitor won't show it
New to overclocking. Can't get you. Mind elaborating ?
Thanks
There are two ways to overclock your processor. Changing CPU multiplier is easier and usually more efficient. For example if your multiplier is set to 32 your processor is clocked 32x100mhz=3200mhz (3.2ghz) but if you change your multiplier to 40 your processor will be clocked to 40x100mhz=4000mhz (4ghz)
There is another way. You can change your bclk. It's (on stock) usually 100mhz. Let's say your baisic multiplier is 32x so baisic frequency is 32x100mhz=3200mhz. By changing your BCLK to 107mhz you get 32x107mhz=3.424mhz (3.424ghz).
You should read a little bit about it, may give you a few additional mhz.
You can also combine both of this methods as I did. I've overclocked my G3258 from 3.2ghz to 4.4ghz by changing multiplier from 32x to 44x so it gave me 44x100mhz=4400mhz. I couldn't push my multiplier any further so i changed my bclk to 101.5mhz so i finally achived 44x101.5mhz=4466mhz (~4.47ghz).
Note that the higer your multiplier is the bigger are changes to your CPU frequency after changing bclk frequency. So don't push your bclk to 115mhz while your multiplier is set to 44x cause it'll give around 5ghz and won't be stable for shure.
Since my cpu has locked multiplier so I maxed it to 16x and changed bclk from 200 to 210 hence giving me 210*16 = 3360 mhz or 3.36 ghz. Note that system is stil stable.
That sounds fine. Try pushing your bclk a little bit more ;)
No...no it does not....
I can tell you with absolute certainty that 4.7GHz is not stock clock.
Your overclocking is done by increasing multiplier and I overclocked by increased bus speed. I guess this might be the only reason that cpu-z does not show overclocked speed.
Yeah I tried to push bclk to 212 but system became unstable intially but later on it continued to be stable upto 220 mhz with temp just under 53℃. I'll try to OCa bit more than 220 mhz.
Same thing, CPU-z reports base clock, multiplier, and resulting clocks accurately even if you OC (I have OCed both ways and it always shows actual values).
Can you share a screenshot of CPU-z? Maybe you successfully increased the base clock, but your CPU idles at less than its max mutiplier, hence why the clock you see at idle is 3.2
Quite amazing.... Last time I used cpu-z it showed only stock clocks even after OC, but this time it showed overclocked value.   @Kahir   @DrMacintosh . I kept on pushing my bclk keeping an eye on temp until system finally became unstable. Take a look. It seems to me that temps are all fine.
What do you think ?
That's a hefty overclock, but you will know whether it's stable and not too hot when you test it under load (there are stress test programs you can use, or you can simply do the most CPU-intensive activity you normally do with your computer to check).
