Fix Reboot and selec prop...
_VOIDNEXUS_
fix reboot and select proper boot device always show up when i restart or open my pc this is only happening now after i formatted my hdd and sdd and put windows on ssd ...
any suggestions???
specs
b85-g43 gaming mobo msi
gtx 960 2g gaming gpu
samsung 250gb ssd
1tb hdd
is the boot device set to the ssd
 Main Desktop
CPU: AMD Ryzen 5 2600X @ 3.6GHz, Stock Cooler
MOBO: ASUS ROG STRIX B350 F Gaming motherboard
RAM: 32GB(4x8GB) Team T-FORCE Night Hawk RGB 3000MHz DDR4
GPU: ASUS ROG STRIX GTX 1060 6GB
STORAGE: 1TB Western Digital Blue HDD, 2TB Seagate Barracuda, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Cougar Turret RGB
PSU: CoolerMaster GX550W CM Storm
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
WIFI: ASUS PCE-AC55BT
https://au.pcpartpicker.com/user/johnno12/saved/gKgD23
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
yes and the only way to surpass the error is by going to bios and setting my ssd as the boot drive then clicking "x"
4 minutes ago, AustinoInc said:
Do you have anything in your BIOS' boot order which isn't being used? Exlude them.
Some of my tips:
  • Make sure you're saving your boot order.
  • Make sure you're not doing a temp-boot order.
  • Ensure your SSD has a good version and non-currupt version of Windows on.
  • Disable UFEI and Fast Boot options temporarily.
•pretty sure its save because every time i go to my bios my ssd is still the #1 boot option
•idk how to make sure of this
•how do i know if i have a corrupt version? i did use an official MS disc
•already disabled fast boot, gonna try disabling UEFI (idk what this is but im guessing its the UEFI usb , UEFI cd or dvd, etc. from boot options)
23 minutes ago, AustinoInc said:
#2 Option is usally called "Choose a temporary boot device." I take it you're not using it as you say that your SSD is in the boot option. Have you tried removing everything but the SSD? You should also try booting into a CD/USB version of an OS, (PenDriveLinux recommended.) to see if it's an issue with the SSD rather than the motherboard.
by everything you mean the other boot options or my hdd?
1 hour ago, AustinoInc said:
Remove everything but the SSD from the list.
If that doesn't work, try booting into another OS - like Linux.
If that doesn't work, I don't know what to recommend.
removing everything but the ssd didnt work
try reinstalling windows from the usb or disc to the ssd
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
wouldnt that delete everything again?
