What LED Strip should I get?
BenNaylor
I need a good quality LED strip to go round the back of my desk and around my PC. I would prefer a digital strip however this is not essential as I would like to also keep costs down. For the strip inside the PC, I have a Gigabyte H170M-DS3M and I don't think it has an led header on the board so I can't connect it there. It doesn't need to be waterproof but I would like a good quality strip with a strong adhesive.
If you don't mind some DIY work you can get a roll of LED's off Amazon and wire them up to 12V power on your PSU or externally if you are just doing surround lighting.
-Moved to Modding Section-
