Search In
  • More options...
Find results that contain...
Find results in...
want to make a pc pls tell me how good the parts are
Hello guys, I am new to pc building and i had a build in mind that i wanted to discuss. Here it is and can you guys please tell me how good it is?
the cpu im planning on adding is the ryzen 5 1500x and gpu is hopefully going to be the cheapest rx vega or rx 580. I will use the rx 480 i the list so it is easier for you guys to get pricing or performance ideas.
  • cpu: ryzen 5 1500x
  • Mobo: Msi x370 sli plus
  • gpu: Msi armor rx480 8gb
  • cooler: stock amd cooler
  • ram: corsair vengance lpx 16gb 3000ghz
  • psu: corsair cx750
  • case: nzxt s340
  • case fans: corsair airflow fans
  • storage: i have a 1 tb hard drive in my home pc which i plan to use in this build and i may upgrade to an ssd in the future
Please let me know how good these parts are. Your help is much appreciated.
Thanks.
They all look good nothing wrong with the list you could go with a 1600 tho and get a cheaper motherboard
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
Get a better psu like an S12ii and downgrade to a b350 mobo and use the money saved to get a 1600.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Downgrade the PSU to 650 or even 550w and get something like a B350 PRO4 from ASRock and then upgrade to a 1600x or even a 1700
If I helped, hit the thumbs up icon below my post and pick it as 'Best Answer'
Resident living meme - I swear a lot; if you don't like it fuck off :^)
  My specs and shit down below.
Apollo: i5 4670K @ 4.6Ghz, Corsair H100i, MSI Z87I, EVGA GTX 1070 SC ACX3, Corsair 250D, 840 EVO 120GB, 1TB Seagate Barracuda, SeaSonic 520W PSU. Planned upgrades: 16GB RAM, 480/512GB SSD, new HDD
Sputnik: HP EliteBook 2570p, i5-3360M, 16GB DDR3, 256GB 840 EVO - Running Win10/Sierra dual-boot.  Future upgrades: i7-quad
Comet (home server): Atom D2500, 4GB 1066Mhz RAM, 2 x 320GB HDDs, 350W PSU, HAF-Stacker ITX, dual GbE. Cost me $80. back from the dead (mobo failure) bois
Main peripherals
- Corsair Strafe RGB MX Reds
- SteelSeries Siberia 650
- SteelSeries QcK+ CS:GO Camo
- SteelSeries QcK+ Na'Vi Splash (Secondary pad, used for second rig)
- SteelSeries Rival 700
- SteelSeries Rival 300 (Secondary mouse, used for second rig)
This may sound a bit weird but my budget depends on my grades in school.
if i do good then my budget can be a little higher than the current list and if i do bad it could be lower.
currently my budget is at a maximum of 1100 Canadian dollars and it could go up or down depending on grades in school.
So considering this can you folks recommend some parts a bit more expensive and some a bit cheaper than the current list.
Also i am trying to get an x370 board for my future sli or crossfire plans.
And as always, thanks for your help.
For cheaper parts I would go off a s12ii powersupply form seasonic as it has really good voltage control and won't harm your hardware while also being quite affordable. For more expensive I would go for a evga g2 series power Supply as they are fully modular and have a high efficiency rating along with outstanding voltage regulation. For cpu I would go with the r5 1600 for a bit more expensive and thre 1400 for the cheaper version.
Just now, Iamgood said:
Thanks a lot dude
no problem. if you ever have any other questions just @me or quote me. always happy to help
thanks for your help means a lot.
now i can order in peace...
  • case: nzxt s340
Thanks.
everything looks good here if you want more silent operation you'll have to fork up the cash for quieter fans but it could be worthwhile also i would suggest a different CPU cooler but that is up to you. you probably only need 650w psu
First PC Build
CPU: i5 4690k  (4.7Ghz 1.36v)                                        MOBO: MSI z97 gaming 5
GPU: MSI GTX 1070 gaming x                  Case: NZXT s340 elite Black/Red
Storage: 1tb seagate SSHD, 240gb PNY ssd                    PSU: Corsair RM750X
Cooling:H100i V2 / Bequiet Fans
16GB Hyper X Fury Memory
Benched on CPUZ (Single-thread=2140) (Multi-Thread=8316)
Fire Strike 1.1=13660
Time Spy=5519
Cinebench R15 (CPU= 509cb) (OpenGL=118.28 FPS)
Unigine (Superposition 4k optimized=5581) (Heaven Extreme=120.6 FPS Score:3038) (Valley Extreme HD= 92.7 FPS Score:3879)
