Whats is best 40-43 inch HDR TV buy now for general use and also gaming?..I use gtx 1080.
I like   Sony 43X800D ..dont know where to buy in UK.. or Samsung 40KU6400 .. which tv is better ? .. or there any other 40 inch tv or monitors this size with hdr ?
YAMAKASI LEONIDAS 30" LCD 2560x1600 IPS PANEL,Cooler Master Mastercase Pro 5
https://linustechtips.com/topic/760063-best-40-inch-hdr-tv-or-monitor/
1 hour ago, Technicolors said:
if you're looking on using a TV for gaming, i would check with response time, input lag, and Game Mode. also the tv should support 4:4:4 chrome
I understand..but need to know which model is best now with HDR
I can spent 1000 pounds for good monitor..but for good hdr tv i like to spend less.around 500 pounds..so later i will use tv as normal tv and buy good hdr monitor when will be available.
it'll help if you quote me next time so i get a notification :)
i would save up for a nice HDR monitor. there's a couple coming soon that may fit the bill, but they'll probably be quite expensive.
Philips makes a good one and there's always the Wasabi Mango.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Might want to check this thread out about using the Samsung as a monitor:
https://hardforum.com/threads/samsung-un40ku6300-40-inch-4k.1901160/
Hope this helps.
Cheers
Hope this helps.
Cheers
I bought Samsung UE40KU6400 40-inch 4K Ultra HD Smart TV  today..because I dont see un40ku6300 in Uk....what can be difference..between this 2 monitors?  also I dont see   Sony 43X800D in UK.
I think I saw that mentioned on the thread I linked above, but now I don't recall it.
But it seemed like a very small difference at the time.
Iq and panel are the same I think.
Anyway, once you set it up, please share some thoughts on it, mainly ghosting, motion handling in gaming and input lag.
Thanks.
Cheers and enjoy your new screen.
