1st Time Water Cooling - Help
Solved by LinusTech,
23 hours ago, rodrosenberg said:I'm a huge fan of the DDC pump res combos so I would move up to that. I also would use the 360 rad if possible since its the slim version. don't get scared of hardline just because @LinusTech avoids it. its really pretty easy and not that expensive so buying a couple extra packages of it to ensure you have enough tubing for your bends isn't that bad and it looks fantastic!
I don't hate it because it's hard to install in the first place.
I hate it because it's hard to deal with if there's any problem - like troubleshooting a bad GPU or whatever.
Also it's hard to install (for me) lol.
