Custom cables for meh new build help plz :)
On 3/12/2017 at 6:32 AM, BrandonIsComputering said:Hey guys, I've finally saved enough to buy the all of the rest of the things that I need for my build but I'm stuck on making the purchase because of the cables. I definitely want custom cables or cable extensions from cable mod or something better if there is a better alternative but my big issue is that I don't exactly know what specific cables to get. I would be really grateful for some help. If it's visible I want it nice neat and color schemed. I just really want it to look nice since I'm dropping so much money on it. Going to buy some cable combs as well.
https://pcpartpicker.com/user/BrandonComputes/saved/JVNQ7P
Intel Core i7-6700K 4.0GHz Quad-Core Processor NZXT Kraken X42 Liquid CPU Cooler Gigabyte GA-Z170X-UD3 Ultra ATX LGA1151 Motherboard G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory Samsung 850 EVO-Series 1TB 2.5" Solid State Drive EVGA GeForce GTX 1070 8GB FTW Gaming ACX 3.0 Video Card Phanteks Enthoo EVOLV ATX Mid Tower Case EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply Corsair Air Series AF120 Quiet Edition 39.9 CFM 120mm Fan Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM 120mm Fans Corsair Air Series AF120 Quiet Edition (2-Pack) 39.9 CFM 120mm Fans Corsair STRAFE Wired Gaming Keyboard Logitech K400 Plus Wireless Mini Keyboard w/Touchpad Mionix NAOS 7000 Wired Optical Mouse GGing Pro gaming mouse pad (extended) NZXT hue+
@BrandonIsComputering for extensions you can check out our basic extension kits, it offers the main visible cables. https://store.cablemod.com/product/cablemod-basic-modflex-cable-extension-kit-dual-62-pin-series/
However your PSU is compatible with full replacement cables if you would rather have that instead of extensions. Your primary cables will be the 24-pin ATX, 4+4 EPS (or 8-pin EPS) and then your PCI-E cables (6+2 pin - two of these) as @brob mentioned.
