 I tried stress testing it via CPU-Z, but it wouldn't go past 1.33 GHz. My specs:
MSI 970 Gaming G motherboard
8 GB Corsair Vengeance DDR3
GTX 1050TI 4GB from PNY
1TB Hitachi Deskstar
FX 6300 at 3.5 GHz
I've tried flicking the slow mode switch on my motherboard and that didn't help.
1 minute ago, HevukoSpace said:
Alright, I have it installed. The temps right now are 16-17 Celcius.
seems impossible unless your ambient temps are very low?
what are your ambient temps?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
If by ambient you mean idling/web browsing (which is what I'm doing right now. I did the stress test yesterday and just started my PC up right now) it's 16-17 Celcius
9 minutes ago, JohnnyCorporalTech said:
What cooler do you have installed?
I have an Enermax ETS N30
ambient just means the temperature of the air in your room.
Looking at your results, it seams that the core voltages are pretty low. Try turning off slow mode again.
Also in the BIOS, set the CPU base clock a bit higher, just another 100mhz and see if your CPU results change.
If your results change, where the CPU clock speed increases from 1.3 to what ever you set the base clock to, it means something is keeping the CPU from boosting it's clock speed. Probably something is getting way too hot.
