Using 2nd monitor with onboard graphics
Hi. I'm having a bit of a problem with this.
I have 2 monitors, both with VGA input. The thing is my graphics card has only 1 DVI-I that I can adapt analogly (I have no idea if that's the right word). I know that with Intel Graphics you can use the onboard connector as 2nd monitor.
My problem is that I have a AMD FX processor. Does anyone know if it's possible to do the same thing?
In case it's needed:
CPU: AMD FX 8120
Motherboard: Asus M5A88-V Evo
GPU: EVGA GTX 660
https://linustechtips.com/topic/750924-using-2nd-monitor-with-onboard-graphics/
CPU: AMD FX 8120
GPU: EVGA GTX 660
You could use a USB Video adapter, as long as you don't plan on gaming on the second monitor.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
1 minute ago, VVoltor said:
You could just get a HDMI to VGA adapter
I can't at the moment. Where I live those are somewhat expensive.
3 minutes ago, deXxterlab97 said:
fx 8120 has no igpu. so that is a bummer. you'd need to connect it all from gpu
But my motherboard has an onboard Radeon HD something. Isn't possible either?
