I'm building my first computer ever and have decided for an m-ATX case and motherboard, I'm thinking about going with the ASUS z270G Strix Gaming, which seems to be the best Kabylake m-ATX board out right now. It's supposed to be the MAXIMUS VIII GENE replacement, but I have noticed that while many new features it's also missing a lot from the GENE like POST code led display, BIOS flashback, MEM-OK start/reset retry SafeBoot clrCMOS button etc. How important are these features if I need to troubleshoot, do resets or if I want to overclock or mess around with the BIOS? I have no experience what so ever with building, overclocking or BIOS, so I don't know how important these features are, but they seem important if I for some reason can't access BIOS or need to troubleshoot, especially the Q-code LED...
https://linustechtips.com/topic/750715-how-important-is-post-code-led-display/
I've never had a mobo with one through my 10 years of building, a speaker is usually enough. Though diagnostics LEDs are quite nice.
REMILIA Mk.IIIE CPU: Ryzen 9 3900X, Cooler: Arctic Freezer II 240 (Noctua NT-H2), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives 1-4 TB, PSU: Corsair RM750 MY2019, Case: Cooler Master Mastercase 5 MC500 (with add-ons, Noctua NF-A14 and Arctic P14 fans), PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), Hp Z27n (IPS, 60hz, 1440p, 8Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, ifi Zen DAC v2 + ifi Zen CAN, Littledot Mk.II (w/ Soviet Power tubes and British Mulard M8100s/Soviet Voshkod 6JP-EV/ American General Electric JAN 5654W dependent on mood), Sendy Aiva (Primary), Beyer Dynamic DT990 250ohm Black Special Edition, Audeze EL-8 Open Back, Sennheiser HD598SE (modified to be a headset, snapped headband held together with gorilla tape), Mouse: SteelSeries Rival 600, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
KOAKUMA Mk.IB (24/7 Folding Slave PC made of spare parts): CPU: Core i7 4770, Cooler: Some small antex cooler with 80mm fan, RAM: 2x 4Gb Sticks of 2400Mhz DDR3, Mobo: Asus H81i-Plus, GPU: R9 390 Nitro+ (barely fits in case), Storage: 256gb Korean no-name SATA SSD, PSU: Corsair CX550 (Gray label), Case: Antec ISK600 ITX case. [Given away to friend]
Just now, snowman89 said:
But won't a speaker just beep twice or whatever if there is a POST fail, but the Q-code will tell me where the problem is?
The speaker will beep out a code pattern to indicate where the failure is. It's just as handy as the LED readout, just not as easy to use for some.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
That's good to know. what about the other features on the GENE that are not on the z270G?
Flashback and MEMOK are nice to have features, but I've never seen them as an absolute deal breaker. A simple CMOS clear jumper works as well as a button, and the likelihood of you ever using MEMOK is low unless you plan on pushing your RAM to it's limits. Flashback is only needed if you install a newer CPU than the board supports and since you're getting a Z270; and Kaby Lake is likely the last CPU to be on LGA1151 before Intel follows their trend and changes to whatever comes next, it's a largely useless feature at this point.
Thanks!
