So i usually connect my headphones to the front panel jack and it is working but the mic isn't working so well. So i tried to connect my headphones to the motherboard but it isn't working. i tried connecting it to the front and it still working (still isn't working quite well). So what is happening here? I remember it was working few years ago. Now it isn't. So can you guys help me?
What does "isn't working quite well" mean? Go to sound control panel and see what you can do from there.. Maybe setting priorities from where the system pulls the audio could help. Again, from what you've told us It could be the headset problem as well..
go to sound control panel
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
