10 minutes ago, magnumkobra said:
Hi a am currentley looking at buying a gelid icy vision used that does not have the ram heatsinks or the vrm heatsinks. Do you know if i could find them anywhere? thanks!
Nvm I just looked at the picture on google. You're gonna need to measure the distance between the VRM and the heatsink and go to eBay and buy aluminum heatsinks. They are like 10 for 1 dollar from china.
For example: http://www.ebay.com/itm/Economic-10X-Aluminum-Heat-Sink-for-StepStick-A4988-IC-ESCA-/222093703703?hash=item33b5d0fa17:g:lKYAAOSwm8VUrOiR
