I'm wanting a nicer RGB lighting strip around 6 feet long that has magnets built in like the Phantek RGB strips but I don't want to have to use Phantek power plugs and my mobo can't control RGB strips.
Basically, i'm looking for an RGB strip I can easily power via PSU but be able to control either via remote or with a clicker button built in to adjust brightness and color.
Anyone have recommendations?
https://linustechtips.com/topic/750478-magnetic-rgb-lighting-kits-around/
Cablemod has exactly what you're looking for. Look up magnetic RGB strips on Performance-Pcs.com.
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
also available on Newegg and Amazon.
Your kits are not cheap and I don't see where I can buy extensions as I need almost 6 feet to cover my case and you also don't have brightness adjustments.
So sell me, why should I buy yours vs cheaper deepcool kit that gives me a remote on top of everything else?
Because buying deepcool would mean not getting magnetic strips?
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
ours come with a remote as well and special widebeam LEDs for a more even lighting effect - however if the price is the only important factory to you - then go for deepcool.
Thanks for being upfront but honestly, I can't justify your cost vs Deepcool being so similar, so I really does come down to price,  much like your cable kits vs Bit Fenix cable kits.  Sorry, but I'm just not made of money
It's fine - we focus on the little details to make a difference which is why our products are more pricey than the cheap OEM competition.
