I need some help in what I need to build a Gaming PC but very specifically (for rpcs3). [Please don't tell me the obvious stuff like "A Motherboard, Case, etc."
I just want some recommendations for building a gaming PC on a budget. $200 USD to be exact.
Someone please tell me what I need..
Specifications:
Runs Windows 10 x64
AMD FX Series, Intel Sandy Bridge, or greater
Modern x86/x64 processor with SSSE3 support
10 GB of RAM or greater
2 TB SATA Drive [RAID0, 1000TB + 1000TB]
Peace!
https://linustechtips.com/topic/747148-help-with-building-a-gaming-pc-on-a-budget/
...Sigh
pcpartpicker.com
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
In short.
G4560
Cheap H110 board
used GPU
cheap everything else.
Desktop:
Laptop:
  • 2 weeks later...
@linus.wut
I saw you were looking at this thread again
https://pcpartpicker.com/list/F97Mr7
this list is a bit over budget, (and has no GPU) but it's the best I can get. I'd recommend you buy a cheap used GPU
you also may want to upgrade the PSU as it's quite low quality and wattage.
Desktop:
Laptop:
