Hey !!!
So while i wait for the email of focusrite support...
I was wondering if it's possible to reduce to x1 the speed of a pci-e slot, and only that one? (theres a pci-e firewire card on it)
I'm asking this to downgrade because apparently in some cases, it worked out the issue, being the firewire card not detecting the focusrite saffire interface.
You can see here: https://support.focusrite.com/hc/en-gb/articles/206849129-My-Saffire-interface-will-not-connect-after-Windows-10-upgrade
(the #1 at the bottom)
Anything changed in my setup besides my computer (im using the pci-e firewire card #1 they suggest) on a asus rog maximus ix motherboard, i7 7700k 32gb ram, a new firewire cable, everything is new and i have more issues than with my older firewire onboard the motherboard of a asus p6t...  thanks for the help :)
Thanks!!!
2 minutes ago, Electronics Wizardy said:
If this happened after a update its probably drivers. Id try using a copy of win 10 ent 2016 ltsb so they are no updates.
no its on a new computer, everything updated to the new drivers.
fresh install of win 10 pro.
Just plug your card into a x1 slot.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
It's the bottom one right?
https://www.newegg.ca/Product/Product.aspx?Item=N82E16813132927&ignorebbr=1
Because i tried and it didnt worked... currently its in the middle one right under the gpu.
Have you tried the other ones? The short length ones are PCIe x1. On some Asus boards, only the x16 slots can run at a older gen, by changing it in the bios. You can still plug your firewire card into the x16 slot.
AMD ThreadRipper 2!
yes i tried 2 of them for now.
2 hours ago, zMeul said:
check manual and see if the mobo allows you tow switch between gen3, gen2 PICe for that particular slot
i think i saw it in the bios but im not sure have to check again
Ok i found the issue.
Drive issue as usual...
It works perfect as soon as i install this
https://support.microsoft.com/en-us/help/2970191/firewire-port-based-device-does-not-work-correctly-in-windows-8.1-or-windows-8
