I'm having issues with my 1070 sc sli. With every benchmark I've seen I'm getting extremely less fps than what others are reporting. The system recognizes that there is sli by showing the green indicator on the left side of the screen and I have the evga hb bridge. I'm trying to game on 1440p. Cooling sits around 55 c while gaming. CPU normally sits around 60ish utilization .Iasasdasd
cpu: i7 4770k 3.5 (oc to 3.9)
gpu: evga gtx 1070 sc x2  (OC GPU clock to about 1900mhz)
Ram: corsair vengeance pro 1866mhz
mobo: asus Maximus vi hero
psu: Corsair HX 850 watt 80+ gold
In the Division I got 62ish fps while running around the streets, 75ish fps when standing completely still.
I also did a valley benchmark.  It doesn't even compare to most of the 1070 SLIs that I've seen benchmark this program. For some reason the cards read 4095MB in the bench mark.  They are 2 GTX 1070 sc and 8gb.
I also ran some benchmarks for GTA 5:
Frames Per Second (Higher is better) Min, Max, Avg
Pass 0, 40.842796, 85.466347, 67.676842
Pass 1, 39.060284, 103.512115, 72.143784
Pass 2, 50.163200, 136.522217, 77.308311
Pass 3, 12.831037, 119.113785, 89.864532
Pass 4, 30.897463, 121.157356, 71.680634
Time in milliseconds(ms). (Lower is better). Min, Max, Avg
Pass 0, 11.700512, 24.484121, 14.776103
Pass 1, 9.660705, 25.601452, 13.861208
Pass 2, 7.324815, 19.934933, 12.935220
Pass 3, 8.395334, 77.936028, 11.127861
Pass 4, 8.253729, 32.365116, 13.950769
https://linustechtips.com/topic/747007-gtx-1070-oc-sli-fps-issues/
1 minute ago, Misterwiggles said:
EVGA PRO SLI BRIDGE HB (1 Slot Spacing) Model 100-2W-0026-LR
Is a weak bridge?
No it's fine.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
