Hi,
I have an i7 7700k @ 4.5GHz and a Corsair H80i AIO liquid cooler.
I am a bit confused as to why my CPU is running as hot as it is.
At idle, it sits around 40 degrees and after testing under 100% load, with prime95, it gets to 80 - 85 degress after 3 - 4 minutes!
Any help with this?
In the bios I have it set to 1.23V and 45 mulitplier. My case also has plenty of ventilation, 2 intake fans, 2 exhaust fans and then 2 more exhaust fans on the H80i radiator.
I have heard in the past Intel chips didn't run particularly well on P95 (overvolting I believe). You could try another stress test like Aida 64 and see what your results are.
Also, I assume the backplate is mounted correctly?
Try new thermal paste.
h80 aint great, not sure about h80i, my temps were worse than 212 evo at same fan volume - it drove me to custom loops
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Just now, NinjaSandvich said:
It is using Arctic MX-2, is that not that good?
I assumed you were using the stock stuff.
Check the backplate is oriented correctly, only one side goes up.
My trial of AIDA 64 Extreme has ended, is there another way I can do it, an online version or something like that?
How do I know if it is the wrong way up? As far as I can tell, it is mounted fine - but I could easily be wrong.
It says in the instruction manual, which you should have read?
Those temps really aren't out of the ordinary for an H80 of any flavor.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 5x 8TB WD White Label/Red (Plex) (both arrays in their respective Windows Parity storage spaces), 1TB Teamgroup MP33 (dumping ground) Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
OptiPlex 7040M
Intel Core i7 6700, 2x16GB Mushkin Redline (stuck at 2133MHz CL13), 240GB Corsair MP510, 130w Dell power brick, Windows 11 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB, PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
ROG RealBench is a good real world stressor. use HWMoniter to watch temps and voltages.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Or any 120mm AIO.
Really need to step up the cooling game OP. Get a 280/360 and you'll be grand. That'll let you properly give it a shot.
I did, and yes, it is the correct way around.
Ok, I'll give it a go :)
I'm not sure if  your using a z170 mobo or not , with my Gigabyte z170x gamming 7 i have noticed my 6700k overvolts to 1.4v even if i have the voltage set to 1.25v, i would check your voltage during a benchmark, if it is overvolting try changing to and adaptive voltage and setting an offset to limit voltage
