i think msi added a dvi port with theirs,BUT there are many cheap displayport to dvi adapters out there
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
Buy the Titan XP, it is a 1080ti with a DVI port, seems that's premium feature now xD
Jokes aside, you could just get a displayport to dvi-d adapter.
Personal Desktop":
Luna, the temporary Desktop:
Yes they will, this is common sense otherwise they will lose a ton of potential buyers just because they didn't add a 2euro adapter. By they way there will be ton of gpu manufactures that will release the 1080ti with dvi=d port so You don't need to worry.
Just now, zzz123 said:
OK thanks. So not must change monitor. Uff thanks guys:) I am waiting for gigabyte xtreme 1080 ti gaming. How long to wait ? 1 month?
yeah it will be out in april.
Personal Desktop":
I'm pretty sure the founders edition comes with an adaptor for display port to dvi
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: TeamSport Elite DDR5 2x16 4800mhz
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Gigabyte G1 Gaming GTX 1080
Case: Corsair Crystal 460X
PSU: Cosrair RM850X 80+ Gold
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
http://www.euro.com.pl/monitory-led-i-lcd/benq-gl2250.bhtml?gclid=CPnChJHoutICFUuLsgod_8sC9w&gclsrc=aw.ds&dclid=CMn3o5HoutICFQORGAodfhUFbA
My monitor GL2250. So easy i can plug 1080 ti ( non reference ) ?
Yeah all cash spend to gpus ,but monitor sux i know :P
9 minutes ago, Froody129 said:
What monitor that only has DVI are you buying a 1080ti?!
edit: sorry, I'm an idiot
I use DVI-D still, could not use it but only had a DVI cable at hand and it does it job so why not? besides people saying that it was a good thing nVidia killed the port are stupid in my opinion, no offenses meant, they took a feature out, the card literally just lost something with zero gains, no other port added, it still is a dual slot card, cooling is unchanged, there literally was no gain for losing the DVI native port so it can only be a loss.
Personal Desktop":
Why on earth are you getting a 1080Ti to use with that monitor? It's a total waste, unless you plan on upgrading within the next year to something with a much higher resolution.
18 minutes ago, deXxterlab97 said:
Why get a Reference 1080 Ti? Why?
Why get a 1080Ti with a 1080p 60hz monitor :P
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Crysis 3
You can play Crysis 3 on a 970 and still average more than 60fps :P
Crysis is past, now its Deus Ex the big first person shooter boy no? haha
Personal Desktop":
Hahah is that the game the kids are playing now? I'll have to keep that in mind :P
4 minutes ago, deXxterlab97 said:
My rx 480 dips below 30fps maxed out.
I was just going by the first review site Google gave me :P
1 hour ago, zzz123 said:
I have BENQ 2250 monitor with only DVI . If i buy non reference 1080 ti
Why would you use a 1080ti for 1080p 60Hz? You would likely be better off getting a 1080 and upgrading the monitor to at least a higher refresh rate IPS panel.
yeah rip game
Self promoting self promoting! Advertising! MODS MODS!!!
Haha :ph34r:
That is pretty low. Are you running a lot of AA?
Maybe it's another issue with that RX of yours.
The fact that I had to watch another ad because I clicked the watch in Youtube link after I'd started the video disgusts me.
Haha :ph34r:
Just maxing out everything for the sake of testing + recording
All the issues are resolved now with a simple DDU. I hope.
Well, I did try to earn some money that way. But I mean you only need a minimum GTX 1080 or maybe 1070 if fps below 60 a bit doesn't bother you.
index.php?ct=articles&action=file&id=25205
