How long will the 1080ti max games at 1080P?
celpas
I am getting the 1080Ti and I want to play games at max settings. Will it be able to do that for at least 2 years?
Are you seriously considering a GTX 1080 Ti to play at 1080p resolution??
tbh for as long as 1080p is gonna be mainstream (3 or 4 more years i imagine)
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
Me rn
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
forever and ever and ever.  It has 1080 in the name.
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
Yes because 1070 has trouble maxing games like Dishonored 2,Watch Dogs 2 and maintaining 60 fps. The 1080 is year old performance and it does have trouble with certain games just like 1070 and I dont think it will keep up once Vega releases.The Ti is 35% faster and using my Amazon gift card I am getting one at 650. I dont think its overkill because eveyone thought the 780ti was overkill but its a 1080p card now. I am also planning a 144hz monitor purchase
100 Years
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
The issue is that game engines are getting more and more efficient, but code and graphics are getting more and more complex it is hard to tell where usage will go.
1 minute ago, celpas said:
Watch Dogs 2
WD2 has issues with everything...
Only if they stay at MSRP; Nvidia said they will (stay at MSRP) but laws of supply and demand, and Nvidia's lack of control over retailers say otherwise if there is too high of a demand.
For years to come, I can't make my Titan XP fail to max out anything on 2560x1080p with fast sync at 75hz, The Witcher, Deus Ex etc...
Damn I really need a 4k tv to replace Toshiba Regza 40inch 1080p, Life is strange max out msaa 8x and I could still get like 200fps in it... I have been using fast sync a lot though to keep the fan running and the card makes barely no sound which is cool.
Personal Desktop":
Luna, the temporary Desktop:
I imagine it'll easily be capable of doing that but you can't always be 100% sure because who knows maybe the next year or the year after games will evolve so fast that it'll be outdated.
4 minutes ago, Qwweb said:
All depends on your CPU as well...
I am getting the 7700K CPU.I was gonna get Ryzen but it was underwhelming for gaming
8 minutes ago, frozeNNN said:
4k will be standard before
I'm just gonna stick with my  1680x1050 monitor until I can get a 4k one for 150€. And 1080ti will max games at 1080p practically until it dies.
My stuff:
CPU :  Intel i5 8400 | GPU : MSI GTX 970 Gaming 4GB
RAM : 32GB Corsair Vengeance DDR4 @ 3600MHz
Mouse : Logitech G502 HERO SE | Keyboard : Mountain Everest Max w/ Cherry MX Brown
Headset : Beyerdynamics DT990 Pro 250Ω w/ AT2020USB+
Monitor : Acer XF240H @  144Hz
I would say just stick with a 1080 when Nvidia's price cut takes effect, save ~$200 to use on other components.
It will but it's not worth at all to buy it for 1080p
4k at 150 euro ? never gonna happen.
Even this day and age a decent 1080p is 200 euro
Let's agree to disagree
are you serious?!
Get a GTX 1080 and a new monitor instead...come on!
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
You'll be fine for quite some time. You can even turn the game's settings to use Super Sampling for extra crispy pixel sharpness with a 1080Ti on 1080p. Or not, and just go for 144fps/144hz minimum at all times probably. Maybe even a bit of Super Sampling there.
Either way you're good :).
i5 3570K @ 4.3Ghz Turbo (OC) | GIGABYTE G1 GTX 980 Ti | G.Skill 8GB RAM | Samsung 850 EVO 2TB
Damn right. That's why I'm just gonna stick with my 1680x1050, because it is good enough.
My stuff:
I am guessing that a 1080 Ti will be able to run games a max settings at 1080p until games start requiring DX13 or require more than 11GB of VRAM.
Unless you are talking about Crysis. In that case, nothing currently can run that nor will anything ever be able to. :P
Sgt. Murphy says, "Never forget that your weapons and equipment were made by the lowest bidder."
But then again i went from 24* 1080p to 27* 1440p 144hz ips freesync for 500 euro so
Im in the same boat. I will proparly buy the gtx 1080ti after its released proparly. And if my i7 4770k bottlenecks too hard on it at 1080p 120hz i will be getting a 1440p 144hz Monitor. Just depends how fast i can hit that 120 fps in most games. Ive heard people with my same CPU getting bottlenecked at even 1440p with a pascal titan x but until i actually see my fps in game and check out my CPU stats and GPU stats whilst playing demanding games at Max settings i cant comment if thats true or not.
