Best next upgrade for my system?
Go to solution Solved by stconquest,
8 minutes ago, wowotek said:
so what do you suggest ? should I pick that cpu or new mobo with the more or less same price dor that upgrade?
If you can afford a new CPU/mobo/RAM, that would be a better idea.
This is the cheapest you should go.  You can upgrade the CPU later on.
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($61.99 @ Jet)  <<To be upgraded to an i5/i7 6000/7000 series.
Motherboard: Gigabyte GA-B250M-DS3H Micro ATX LGA1151 Motherboard  ($73.77 @ OutletPC)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2400 Memory  ($51.99 @ Newegg)
Total: $187.75
Generated by PCPartPicker 2017-02-16 05:43 EST-0500
I Got H61m-DS2 Gigabyte 1155 socket motherboard with intel i5-2310, 8GB ram and eventually came to my vga. It's GTX1060 3GB.
I am really confused what should I upgrade while I got limited choice.I actually don't have any plan to buy new motherboard. but whatever your suggestion I take it. I just don't want to bottleneck my system anymore. thanks !
cpu
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
1 minute ago, wowotek said:
what cpu and why ?
the 1060 is fine but the cpu will be holding you back look at an I5 6500/ 7500 (you will need new mobo/ram)
PSU tier list-
Total: $187.75
