Noctua Fan
Solved by SCHISCHKA,
11 minutes ago, CHEESYnachoMAN4 said:Are the rubber corner things worth it tho i already ordered them should i keep them or no?
Also should i keep the redux fans or return them and get better ones?
redux are fine, just as good as the brown ones. corner things are not required
cheersalt1 ·
Posted in Cases and Mods0 -
ProtonicGamerz ·
Posted in Graphics Cards1 -
ArcticArua ·
Posted in Troubleshooting0 -
4
play_circle_filled
Latest From Linus Tech Tips:
Why Do Youtubers Keep Destroying Companies - WAN Show April 19, 2024
