Search In
  • More options...
Find results that contain...
Find results in...
Wierd noise, help please
So I just upgraded my pc to a gtx 1060 from zotac
Its good at running games now and all that
But my pc started giving out wierd noises
Im not sure from where since the gpu's fans arent spinning, the only moving parts are the exhaust fan, cpu fan and the psu fan
and the HDD
help?
and the HDD
help?
Coil Whine?
1 minute ago, Unexas. said:
Coil Whine?
Idk
It's never sounded that way before (not that i know what coil whine sounds like
I'm worried that the PSU is weak or something
My old gpu didn't need any extra power
1 minute ago, MAT0S0 said:
Idk
What PSU?
1 minute ago, HydraGaming said:
Describe the sound, "weird" doesnt say much.
Its like a scratching sound
imagine scratching 2 rocks together
something like that
It only starts to let out those noises when I turn on a game like overwatch
3 minutes ago, Unexas. said:
What PSU?
A psu from some company called HKC
a 250w unit
a 250w unit
Ok You are most likely at the limit of that PSU i would get a new one stat before i blows up.
something like that
So nothing like this?
Fishy indeed, can you open the side panel and try to find which component that is making the sound?
If its GPU i suspect it has to do with If its any fan i suspect its that the motor has gone bad, if its PSU however i would try to get it replaced soon.
Edited by HydraGaming
Re-read original post
Hey man upload a video of the "sound" and we can help you after that. Otherwise, it seems like you don't know what it is at all. Either that or describe the sound. Is it oscillating? Whining? Metal on Metal? Plastic? Fat? Bouyant? Water/liquid? etc.
"I don't try to be smart, I try to observe. Millions saw the apple fall, only one asked "why?""
it could be a fan grating against something ?? like lukes said please upload a sound clip for analysis
Thread moved to Troubleshooting section
If you need help with your forum account, please use the Forum Support form !
VPN server guide
Introduction to Mechanical Keyboard
My Gaming Rig - Motherboard: MSI Z370-A PRO CPU: i7-8700 RAM: 32GB DDR4 2400(4x8GB) GPU: Gigabyte GTX 1060 3GB OS SSD: 240GB Avexir E100 Storage: 2x 1TB Seagate PSU: Seasonic G650 OS: Windows 10 Pro 64bits Monitor: Acer 21in G205H + Lenovo 21in
I would try and record it but im sure that it wouldnt be audible enough for my phone / camera
And i came up with 2 conclusions already:
-Psu is being pushed over its limit and needs replacing
-Gpu coil while which ill have to live with if thats the case
