Advise for my build?
Hi everyone,
I recently posted my build on this forum. I got really good advise from you all, thank for that! Now I changed some components and want a last advise. :D
I got a few tips to change my gpu to a 1070 and get other cheaper components. Unfortunately that is, In my calculation, not possible. A gtx 1060 is 330 euro and a gtx 1070 500 euro. That's just to much for me. But if you can change components the way I can buy the 1070 thnx! xD
I have 1000 euro to spend and don't need to buy RAM, Case, HDD and SSD myself.
My build:
CPU: Intel core i5-7600K                          €   260,95
CPU cooler: NZXT kraken 41x                  €  84,-
Motherboard: asus rog strix z270f           €  192,50
GPU: asus rog strix 1060 OC 6GB          €   335,-
PSU: corsair RM650x                              € 105,95
In total:                                                    €  976,50
RAM: corsair vengeance lpx 8GB 3200MHz (2 sticks so 16 in total)
HDD: WD 2TB 7200RPM
SSD: samsung 960 EVO 500GB (pci m.2)
Case: NZXT H440 Razer edition (already bought this one, I got 50 euro discount :D)
Thanx in advance!!!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
Where are you buying from?
CPU: Intel core i5-7600K                IS the same thing but higher clock rate I would try to get a i7 6700k Or a i5 6600k
the cheapest shops I can find in europe. I'm living in the Netherlands so I for instance buy my GPU on the german amazon but my Mobo on a dutch site
So you can order from any European shop?
id get a cheaper z170 motherboard and 6600k if they are cheaper. also you could go for a less expensive cpu cooler. you could also buy a cheaper psu as long as its a tier 3 or above.
