MSI R9 280x 3G Performance Problems
Guest
Hi all,
So I've recently been having problems with my MSI R9 280x 3G. I reinstall Windows 7 (Home Premium x64) about 2 weeks ago, ever since performance there have been two seperate issues.
Problem Number 1
The first of these is that the card under-clocks down to 301mhz for no apparent reason mid-game, causing frame drops. Temperatures tend to hold at around 60-65 degrees Celsius under load, which shouldn't cause thermal throttling right?  This happens in pretty much in any game from TF2 to JC3 and even USFIV and under varying amounts of load from 15% upwards.
Problem Number 2
The card seems to be under-performing in general, for instance when I was playing  Shadows Tactics: Blades of Shogan (link) it was running at 15-20 fps on high and even medium presets although it's way above the recommended specifications.
Information
Full build: https://pcpartpicker.com/list/JfC9wV
Driver versions from Radeon Settings:
Radeon Settings Version - 2016.1204.1136.20853
Driver Packaging Version - 16.50.2001-161204a-309274C
Provider - Advanced Micro Devices, Inc.
2D Driver Version - 8.1.1.1583
Direct3D® Version - 9.14.10.01235
OpenGL® Version - 6.14.10.13464
OpenCL™ Version - 21.19.384.0
AMD Mantle Version - 9.1.10.0165
AMD Mantle API Version - 102400
AMD Audio Driver Version - 7.12.0.7723
Vulkan™ Driver Version - 1.4.1
Vulkan™ API Version - 1.0.30
Thanks in advance for any help, just ask if you need any more info.
Your CPU might be bottlenecking it, but other than that, I have no idea.
No, 8320 is not that shit. Might be a driver related issue or Windows related issue.
4 minutes ago, Alec M said:
@Matu20 Bitwit did an AMD build with dual RX 480s and a 9590, it performed terrbly.
Most games over 60fps average, yep, definitely terrible.
2 480's are massively faster GPU's than a 280x.
This is like saying oh that 6600GT will bottleneck with your i5 2500 because a TITAN XP does.
i7 5930k - 32GB Gskill Trident 3200 - EVGA x99 FTW-K - RX 480 8GB Nitro Crossfire
This is like saying oh that 6600GT will bottleneck with your i5 2500 because a TIRAN XP does.
What are you talking about?
6 minutes ago, huilun02 said:
Give this a try
Obviously not a CPU bottleneck as you said it only started recently.
Don't mind the asshats here who jump at every opportunity to put blame on AMD processors.
Yeah I was gonna say, seems unlikely it's the CPU.
I am talking about the idiot saying his 480's were bottlenecked, they are not even the same tier of GPU as a 280X.. 280X is way less powerful.
Okay, this is exactly what I was thinking. Somehow I thought you were attacking me :D
Using MSI AB, increase the Power Limit to the Max.
And also, click Extend Unofficial overclocking limits and Disable ULPS.
This helped with my RX 470 being stuck at 800mhz, now it's at 1226MHZ Boost.
22 hours ago, huilun02 said:
Give this a try
Thanks I'll give it a shot when I'm home .
I'll also give this a shot thanks .
Don't forget the apply the max power limit as you have to save it, it'll have to take a restart though.
4 hours ago, huilun02 said:
Give this a try
Bro, do you even AMD?
You are slamming someone who has had experience with an AMD processor for a while.
Also my original post only gave an idea, not a OH YEAH THIS IS HOW IT IS sort of post.
Also, I didn't even see that he stated it had started recently. So please just chill it.
Doesn't seem like it's had any effect, is there a reliable tool I can use to judge?
If u are using the latest drivers , try rolling back a couple of drivers , use WHQL only
and put ur power mode to high performance ( just in case ) .
check the thermal threshhold temp as it might be set too low in the driver .
i would place a bet that this el cheapo 4 phase VRM asrock board is not designed strong enough to sustain power delivery to this AMD FX pos and the CPU is probably trottling because of that which makes the GPU load and FPS go down.
OP, i would start by checking the CPU clocks and see what is happening there ;)
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
