PC Case Air Pressure Investigation Pt. 1
Buy Fractal Design Define R5 on Amazon: http://geni.us/TbOYJ
Is there a meaningful difference between air pressure configurations in your PC case? Luke investigates...
A year after, Luke forgot about it completely
there is no pressure difference with low RPM fans. If intake/exhaust is pushing more air it just flows through. You need 6000rpm server fans to create a meaningful pressure difference. I did this and the case did collect dust in all its gaps but they sealed/clogged themselves up and there was not much dust on the components
ψ ︿_____︿_ψ_
11 minutes ago, deXxterlab97 said:
-snip-
Have they even used a UPS or eletrical surge protected extension xD? Also, old parts that we have no idea if theyll last a whole year working properly, lmao :P.
Groomlake Authority
So long as the PSU itself lasts, then it can keep the fans running (assuming a molex connection). The parts are probably just there for the sake of collecting the dust, rather than actually being powered...
...either that, or I hope they are at the very least using those machines for something (say, F@h / Boinc) instead of just wasting a lot of electricity.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Or... a year later they could be gone
Bonus: Luke doesn't shave or trim his beard for the length of the "experiment"...
Code-name Nyx: R7-3800X w/ Scythe Fuma 2 Rev. B | Sapphire RX 5600XT | Gigabyte B550i Aorus Pro AX | Patriot Viper 4 Blackout | 3TB NVMe Storage| Cooler Master NR200 | Kubuntu/Windows 11 | Xiaomi Mi Curved 34" | Keebwerk Mega | Logitech G602 | Audio Technica ATH-M40X| Edifier e25 Luna
Quote
no one has done a benchmark about this
except for the people who run this setup for months/years ?!
So was this video filmed one year ago and we're gonna get the results soon-ish, or do we actually have to wait a year after this teaser?
Knowing LMG, something will go wrong before it's finished :D
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
11 minutes ago, Imakuni said:
-snip-
I dunno, those yellow motherboards scream 2005-2007 and have they even packed in something worthy in there other than some sort of Intel quad or duo processor xD? Hopefully this test doesnt end up a bust, by them saying "we had a small quake in office :D".
Groomlake Authority
So are the machines at least folding while they idle for a year? Also I hope there is a UPS hooked up or at least some sort of way to make sure they are still on in a month if power goes out...
Pretty sure he meant that no one has ever done a long term experiment like this with uniform starting and running conditions, except for the variable in question.
They're in Canada, they'll get a blizzard, the power will be knocked out and they'll forget about the pc's until Lukes calendar reminds him in a year. In which case they will have been off for 6 months.
one month should be enough
Hey Luke, I REALLY hope you filtered all the intakes of the Inny PC. Otherwise this exercise is pretty pointless - the theory that positive airpressure reduces dust ONLY works if all the intakes are actually filtered.
CPU: AMD R5 5600x | Mainboard: MSI MAG B550m Mortar Wifi | RAM: 32GB Crucial Ballistix 3200 Rev E | GPU: MSI RTX 2070 Armor | Case: Xigmatek Aquila | PSU: Corsair RM650i | SSDs: Crucial BX300 120GB | Samsung 840 EVO 120GB | Crucial m500 120GB | HDDs: 2x Seagate Barracuda 4TB | CPU Cooler: Scythe Fuma 2 | Casefans: Bitfenix Spectre LED red 200mm (Intake), Bequiet Pure Wings 2 140mm (Exhaust) | OS: Windows 10 Pro 64 Bit
Why don't you guys just have the case fans run through the psu? That way power isn't wasted on idle performance
just a suggestion ^^
can't wait for the results
okay okay okay i just watched the video.
And there are two things that i wanna know @Slick
1. Why use a full set of hardware and not just a bunch of fans?
2. If you are using hardware anyways, why not at least get a real GPU in them and do some Folding at Home/Boinc?
Also: Luv u slick <3
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
or it's gonna delay for few more years
inb4 somebody else removed the power cords from the wall because they thought those wasn't important.
Yea, he didn't specifically say but unless he put filters on ALL the intakes (including the rear and top) this is a pointless experiment. @Slick Did you guys do this?
I have a weird fan setup on my PC (rear intake) but I installed a filter on the rear and bottom intake since the case didn't have any there. I've only dusted it once since building it in May but it didn't even need it:
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
I hope this doesn't happen... but hey, anything is possible. We've set reminders just in case something DOES happen.
