Motherboard is getting power, but not outputting video
This is round 2 of building a home server, and I'm having motherboard issues yet again. The motherboard is getting power -- I know this because the fans spin when I turn it on -- yet it displays no video output on the onboard VGA. The monitor and VGA cable I'm using work perfectly fine. I can't troubleshoot using a video card because the motherboard only accepts older PCI or AGP cards.
Any ideas on how I can get the motherboard to output video to my monitor? The motherboard is the SuperMicro X7DWN+.
Motherboard page: http://www.supermicro.com/products/motherboard/Xeon1333/5400/X7DWN_.cfm
COMIC SANS
Does the CPU have an iGPU?
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
I thought it did...? It's the X5472. ARK didn't mention anything about it.
http://ark.intel.com/products/34447/Intel-Xeon-Processor-X5472-12M-Cache-3_00-GHz-1600-MHz-FSB
Bought the motherboard, CPU, and RAM from a fellow forum member, who kindly hasn't charged me for them yet until they work. He tested it out before shipping it to me, and it worked for him. I'm assuming he used the onboard VGA.
COMIC SANS
Buy a cheap gpu to test?
XFX PVT44AWANG GeForce 6200 256MB GDDR2 AGP 4X/8X Video Card (VGA/DVI/S-Video) https://www.amazon.com/dp/B000CQ73PW/ref=cm_sw_r_cp_api_Vg3qyb9DYV7PK
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
Man, just looking at that thing puts me in an internal civil war.......
Just now, wrathoftheturkey said:
it doesn't
That would explain it.
Doesn't have an igpu unfortunately.
Thanks guys. I'll get a cheapo GPU try that. PCI-E cards don't fit though. PCI and AGP only. I'll try to find something local so I can test tomorrow. If anybody knows of any Amazon listings for PCI or AGP cards with next day shipping, let me know.
COMIC SANS
I just noticed that the *motherboard* has integrated graphics. I would imagine it would still work. I'll still try using a video card though.
COMIC SANS
2 minutes ago, TopWargamer said:
 integrated graphics
I think that just means that it has support for CPUs with integrated graphics.
"ATI ES1000 Graphics with 32 MB video memory"
COMIC SANS
Oh, well then the boards graphics are probably dead
I got half way through this thread wondering if anyone would realize that it has integrated graphics on the mobo itself.  I'm glad somebody caught it.
That said, I would suggest trying to figure out the mobos' POST beep codes or however else it communicates if it's successfully POSTing or not and where it's failing for diagnostics before assuming what is and isn't dead.
Quote
long and two short beeps - video confi guration error
1 repetitive long beep - no memory detected
1 continuous beep with Front Panel Overheat LED on - system overheat
If this doesn't help, a POST Code Debug Board should have no issue reading port 80h and spitting out a much more specific error code.
What if there's no beeps? Because there's no beeps when I turn it on.
COMIC SANS
Is the internal speaker jumper shorted?
Quote
Power LED/Speaker
On the JD1 header, pins 1-3 are used for power LED indication, and pins 4-7 are for the speaker. See the table on the right for speaker
pin definitions. Note: The speaker connector pins (4-7) are for use with an external speaker. If you wish to use the onboard speaker, you should close pins 6-7 with a jumper.
Maybe...? I'll check in a bit. Thanks for the info.
COMIC SANS
I'm just reading the manual... and wondering why you aren't reading the manual instead...
Are all of the power connectors connected?
There is the 24 pin, an 8 pin eps, and another 4 pin eps. These all need to be connected because it is needed to power both the exta cpu, and the fb dimms which use a lot of power.
If you don't have all the ram slots full they also have to be in a certain configuration for either dual / single cpus.
You could also try a post code reader to see what it stops on, and then google it to see what the problem is.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
I just had to deal with a SM board that did nothing (no post, no beeps) when I installed it, too.
Before SM boards post or do anything really, they perform a check to see if everything is ok - after that they POST.
In my case, i installed CPU & RAM, started the server, FANs started, but nothing else happend.
So the first thing to do, is to remove all the RAM and PCI cards currently installed. If it does not beep then, the boards seems pretty dead to me..(assuming PSU and CPUs are already checked)
If it beeps, install your DIMM one after another and see how far you get. in my case, filling the DIMM C1 slot always prevented the board from POSTing. But it could be dead or wrong RAM sticks, too.
If it works with RAM installed, start inserting your PCI cards and see if one of those prevented it from POSTing.
  • 1 year later...
Try to start with 1 CPU then it must be works with two CPU and video
