Search In
  • More options...
Find results that contain...
Find results in...
Is there a way to connect my home desktop PC directly to ethernet cable, while still having wifi around the house?
Whenever I connect directly to my modem via ethernet, the rest of my house has no more wifi. I'm not tech savvy, so what is happening here? Can it only be one or the other? Is there a way to make it work? Wifi gives me a lot of packet loss, so I want to connect directly to modem while still allowing other devices to work around the house.
PICS: http://imgur.com/a/re7jf
1 minute ago, Electronics Wizardy said:
Do you have a router? Don't plug your desktop into the modem, plug the desktop into the router.
I get a ton of packet loss if I do this; the packet loss is gone when I connect directly to modem. It's just that no one else can use the wifi if I do this.
Get a proper router.
PSU Tier List LTT Gender Survey
LTT's self-appointed memelord
Always up for a game of chess
See @STRMfrmXMN @Energycore or @Starelementpoke for PSU needs
See @deXxterlab97 for blue fetishes (if that's your thing)
See @ShadowTechXTS for cats
@Implosivetech's got you covered for all your graphic design needs
And lastly, never put a CX green series PSU in a high end build https://youtu.be/Oybz5Q-If9M?t=7
What do you mean by packet loss?
You should never connect your computer directly to the modem, it a huge security problem.
You might want a better router.
The thing you need here is a Router, get yourself one of those wireless routers with Ethernet port's'
Your router sucks.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
Wait is the Modem provided by the ISP or is it one of those MODEM+Router Thingy you bought yourself!
3 minutes ago, Litargirio said:
Your router sucks.
yes, sounds like the worst thing ever tbh, like REALLY SHIT to the pont where a monkey sending morse code would do a better job lol
I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally)...
Builds:
1 minute ago, a2242364 said:
my router is DIR 615, how fucked is it?
Hey can u please explain ur network setup please! Would help a major time!
network setup? not sure what u mean T_T
Insert   Dank   Signature   Here.
i mean how are you getting your internet connection, example: if you are getting it through a phone line then it connects to the modem provided by he isp and then to the router
2 minutes ago, a2242364 said:
any budget recommendations
The way it works is you tell us how much money you want to spend, and we tell you what router to buy at that price.
crap. well it's definitely not a phone line. there's some long white wire that goes into my wall and connects to the modem, and then to the router. sorry, probably not helpful :/.
true lol. idk what routers go for these days, under 100?
Having a 'packet loss' as you are saying is really strange like even the shittiest routers i have ever had havent had this issue! Though try resetting your router or if the thing is upgradable , then upgrade its firmware!
ok random issue popped up. trying to access router settings to upgrade firmware, but i cant access 192.168.0.1. chrome says site cannot be reached? any idea why?
try 192.168.1.1
is your router connected to your PC first of all, if yes then just connect the router to your pc,i.e., the modem in no way should be connected to your pc or to your router, then try accessing !
2 minutes ago, Litargirio said:
try 192.168.1.1
no dice. 192.168.0.1 usually worked. not sure why it's not right now.
