Leather Cuffs - How to keep them soft?
Mendozacheers
I have had a pair of ATH-M50 for about 6 months, I absolutely love them but the leather ear cuffs have gotten dried up, they are not soft to the touch anymore. I have only had cloth ear cuffs on my previous headsets and headphones - So I don't really know how leather become. I just purchased a pair of new cuffs for them and they are soft again, I want to know how to prevent them from drying up again, if it's even possible?
Case: Fractal Design Define R4 | MB: Asus P8Z77-V PRO | GPU: x1 Asus DirectCU II OC GTX 680 (2GB) | CPU: Intel Core i7 3770k | RAM: 32GB 8x4 Corsair Vengeance DDR3 1600MHz | PSU: Corsair TX 750W | Sound Card: Sound Blaster Zx | SSD: Intel 520 Series 180GB (Boot & Windows) | HDD: WD Green 2TB (Steam), Samsung HD501LJ 500GB (Storage), External Seagate 500 GB (Storage) External WD 1TB (Storage) | CPU Cooler: Corsair H100 | MonitorLG IPS 24" 1080p | Keyboard: CMStorm Quickfire TK Blue | Mouse: Corsair Vengeance M65 Performance | Headphones: Audio Technica ATH-M50 | Speakers: Creative Gigaworks T20 Series II, Roth Oli POWA-5 Black | Microphone: Samson Q1U | Mobile Device: Samsung Galaxy S6 Sapphire Black (32GB) | Tablet: Samsung Galaxy Tab 4 7" (32GB) | Notebook: Lenovo ThinkPad Edge E540 | Steam: 4500+ Games
Steam | Twitter | Twitch
Maybe use some shoe cream? You know the thing that makes your shoes look shiny and soft :)
If that does not work there is plenty of creams designed to "satisfy and impregnate" leather around :) Just search for "leather softener" ^^
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
Maybe it's because your sweat causing contract(ion) while it takes to cool down after using it?
It's fake leather, not much you can do about it.
Uh, a question, I'm getting an ear cup replacement, which ear cup material has long lasting use?
Don't know if it will last long but the velour pads on my DT770's are supercomfortable and they stay soft.
THE signature
You can replace the pads, or sock mod, but you are never getting the pads to not be rocks.
Cloth/velour is usually good. Or buy real leather and take care of it.
Anywhere to get custom leather cups, specifically for the ATH-M50. I know I can just google it, but if there's a specific trustworthy site with good deals?
Lol, I wouldn't waste that much money on those headphones. If you are looking for something like that, go into the DT series.
I would pick up the 770 or 990 with the velour pads. Can be found for as low as $100.
the single redeeming factor of owning a shitty turtle beach headset is that the earcups are directly interchangeable with my m50. I now have the choice of using the papery thin pleather and a cloth cup although it does feel like it changes the sound a bit
when I get around to it I'll likely be using some interior car cleaners on my m50 earcups to see if they soften up again
I can't find any velour ear cups that ships internationally. Anyone know which site I can buy them at a decent price?
EDIT : For my A900x. Does it affect the noise isolation like audio leak or something after I change them to velour?
Velour isolates less than pleather/leather. Truly have no idea about international pad-buying options.
