Why does upload speed in UK suck so much ?
Thony
http://www.speedtest.net/my-result/5763087903
Less than 10% of download, im so disgusted... Is the infrastructure in this country this bad or is it ISPs being assholes ?
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
Because the isp decide the speeds, thats about it
CPU:R7 5800X    Motherboard: asrock x470 taichi ultimate   RAM: 32GB G.Skill Ripjaws-V 2X16GB    GPU: Gigabyte GTX1080TI gaming oc 11g   Case: Corsair 600Q Storage: 1TB Samsung 870(boot), samsung 850evo 500GB, 2TB Corsair MX500, samsung 2TB 970 evo plus, WD 5TB black    PSU: Corsair AX860    CPU cooling: Corsair H105
Have you tried other locations ? I have to do that sometimes to see what my speed is.
CPU: Intel i7 7700K | GPU: ROG Strix GTX 1080Ti | PSU: Seasonic X-1250 (faulty) | Memory: Corsair Vengeance RGB 3200Mhz 16GB | OS Drive: Western Digital Black NVMe 250GB | Game Drive(s): Samsung 970 Evo 500GB, Hitachi 7K3000 3TB 3.5" | Motherboard: Gigabyte Z270x Gaming 7 | Case: Fractal Design Define S (No Window and modded front Panel) | Monitor(s): Dell S2716DG G-Sync 144Hz, Acer R240HY 60Hz (Dead) | Keyboard: G.SKILL RIPJAWS KM780R MX | Mouse: Steelseries Sensei 310 (Striked out parts are sold or dead, awaiting zen2 parts)
The UK has a major infrastructure issue. In this case the height of performance being rolled out across the country is VDSL, which is still running over the old copper phone lines, its a shorter run but its still basic unshielded copper. The way it works is it assumes a consumer on the end of that line and that it is more beneficial to assign 90% of the frequencies to download. The alternative you would have is about 20/20 instead of 2/38, since most of the time you would be getting better use out of the download that is the way its setup.
This only changes when you go to a true bidirectional mechanism, at which point up = down.
Its the closest. Changing it wont increase my upload by 2mbps....
4 minutes ago, CookieMaster said:
Better than mine, Live in the US.
Well cant compare US with UK. Its like Jupiter vs Earth :D
I live in the caribbean and my upload speed is supposed to be around 15mbps and I don't even get close to that unless I ping a server in florida
its like that in the US too. ISP's know that most people don't use their upload nearly as much as their download, and so they "save money" (barley anything) by reducing your speed. it also entices people to pay a hefty bit more for a slightly higher speed.
I dont wanna hear it
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: ASUS RTX 2080TI | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
http://www.speedtest.net/results.php?sh=ccd502f4844bd167e3543a2149cd8181&ria=0
What are you on? You don't see my stable 19Mbps upload? :) (but fuck me, rip 15-16Mbps of down speeds since I got this FTTC installed ;-; Useless talktalk modem/routers not supporting the feature that was supposed to increase speeds...only if they supported G.INP)
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
Their website says upp to 2mbps upload so its not the server.
1 minute ago, Curious Pineapple said:
http://beta.speedtest.net/result/5763144886
And I live in a town with prehistoric phone lines
Yea their higer tier has torelable upload speed, its this low and mid tiers that are pissed on with almost every ISP...
Don't worry, if G.INP is live on your cabinets and if you have a HG663 then you'll find your download speeds lowering quite dramatically :/
My speeds for example, 2 months it took for the first jump in speeds (yes, 5Mbps lower speeds overnight) so...rip
If you'd like to know why your speeds lower then I can explain it to yer ;)
True true ;) (Virgin is the only ISP that has separate lines from BT on a national scale but they use P2P apparently so during peak times, your speeds dip dramatically...)
Yea I had Virgin media for very long time in different locations. SOme locations were so bad that at 7pm your wouldnt be able to load Youtube... but other websites were fine.
I still remember using them in my very old house...stable 20Mbps (then 30 when they put everyone's speeds up) as there wasn't many Virgin users in that area :P
The Brexit strikes again
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
Nothing to do with it unless they decide to say "Internet comes from US and therefore we need to increase prices" :D
Do you guys know if ISPs in the UK are going to be switching over to the Docsis 3.1 standard?
Look at my shitty upload speed -.-
Upload speed sucks everywhere on Residential internet. Most ISP's do not want residential internet hosting web services ( FTP, HTTP, Game Servers, etc. ). It's also a preventive measure against botnet's and DDOS attacks.
I wouldn't mind giving up a little down for a bit more up... VM (and ntl before them) have always been skimpy on upload compared to ADSL which have a smaller ratio between.
Main system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance Pro 3200 3x 16GB 2R, RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Yo waddup. Upload is horrible but...I talked to one of my tech guys and he said the ISP does not want to increase any upload because it costs alot more. I mean I wouldn't mind sacrificing a little bit of download for a little more upload though.
