120 vs 140mm case fans positioning
Mr_Random_Guy
I'm getting the cooler master mastercase pro 3 soon and it has space for two 120/140mm fans in the top (exhaust) and space for two 120/140mm fans on the front (intake). I have two 120mm 1500 rpm fans I'm going to put in, and the case comes with two 140mm 1200 rpm fans. So my question is: which size fans should be intakes or exhausts?
Thanks in advance
More in than out.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
3 minutes ago, soup said:
More in than out.
Agreed. I currently have 2x140mm intake and 2x120mm out fans, it's the perfect balance to limit dust accumulation while still getting good airflow to blow out hot air quickly
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
If you have filtered intakes use them. As long as you have a strong intake from the front of the case with multiple exhausts in the back it should be good.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
