Silent 92mm fans?
Automobili3XF
Recently i noticed my case has almost no airflow on the inside, and with the summer coming, this may be a problem.
I have some spots where i can mount some 92mm fans for exhaust.
I tried using some Power Mac G5 Delta fans (3 blade, 4-pin molex, 4000RPM) that i had laying around and those are sooo loud, i mean, like jet plane loud.
Do you guys know any silent 92mm fans?
I'll exclude Noctua fans right off the bat, because we can't get those here in the country.
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
Bequiet silent wings 2.
6 minutes ago, Nacho Marco Segui said:
Arctic fans are actually nice and pretty cheap, Fractal design Silents fans are also good.
I second this. I have a PC with this fan, and I can't hear it at all.
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
I couldn't find any Be Quiet or Fractal fans, but weirdly i found a store that sells Noctua and Arctic fans, WAZ.
They have 3 different 92mm fans: Noctua NF-B9 (Redux and standard) , Noctua NF-A9 and the Arctic F9.
What should i get?
What should i get?
The Redux version just comes without extra accessories and is otherwise the same.
The NF-A9 is an updated and higher rpm version to the NF-B9. They're both excellent fans.
The Arctic F9 isn't as good as the Noctuas but still alright.
Can you link us to where you're shopping?
This store, in Brazil:
http://www.waz.com.br/cooler-gabinete-9cm-noctua-nf-b9-1600.html
http://www.waz.com.br/ventoinha-cooler-9cm-noctua-nf-a9-pwm-112276.html
http://www.waz.com.br/cooler-gabinete-9cm-noctua-nf-b9-redux-1600.html
http://www.waz.com.br/cooler-gabinete-9cm-arctic-cooling-arctic-f9-pwm.html
