Will my 450 Watt PSU Be enough for the new Geforce GTX 750ti i'm buying ? [Specs inside]
Current PC Specs :
CPU : Inter Core 2 Quad Q8300 @2.50 GHz
GPU : Nvidia Geforce 9400 GT (16 Cuda cores , 1 GB Memory)
Some 5-6 year old Intel Motherboard
500GB HDD Samsung
2 x 2GB DDR2 Memory
1 CD-DVD Writer/reader
PSU = Intex 450 Watt PSU
I'm buying the Zotac Geforce GTX 750ti Which says 400 Watts is required. Will My PSU handle it ? or is it time to upgrade , I'm just a small time budget gamer , so i'd really like to not buy a new PSU
I'm Using a UPS btw.
Please Help. :)
You'll be more than covered. Have you looked into the 950 75W?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I suppose youd be fine but you should never be maxing out on wattage personally id go with a 650 its not too expensive and would be more than sufficient
With a newer gpu like a 1060 I would say no problem but depending what else you have going on with the older 750 ti you may have an issue I think it recommend 500w
The 750Ti is much more low power than the 1060. Both could run on a 350W PSU.
USEFUL LINKS:
PSU Tier List F@H stats
9 minutes ago, EnemySp0tt3d said:
You can get a gtx 950 for $90 off amazon with a mail in rebate.
I'll look into it , Ty for suggestions :)
300 watts for a 750Ti paired with a 3770K would even be more than sufficient...
650 is more like... dual 970's and 5960X...
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
3 minutes ago, iamdarkyoshi said:
I'm running a 750ti and i3 4350t off of a 100w psu, you will be fine xD
You serious ? i need some screenshots :D:D
Its in my desktop laptop project. Its a picopsu style wide input range DC-DC converter about the size of a tv remote. Yes, it will run on batteries.
Handles aida64 cpu+gpu for hours.
Here's a system with a 750 Ti and an oc'ed 3960x pulling only ~200w at load. http://www.guru3d.com/articles-pages/nvidia-geforce-gtx-750-and-750-ti-review,5.html
How
I'm pushing 200w into my 3930k alone
Umm can you give me a link , i'm not from the west , so it might not be available in my country
How
Read the article. They turn off power saving features and stress only the graphics card to figure out how much power it draws.
22 minutes ago, R3-Flex said:
Current PC Specs :
500GB HDD Samsung
2 x 2GB DDR2 Memory
Please Help. :)
You should be fine but instead get a RX 460 which is better for the same price and same power (some have 6-pin connectors, get one that doesn't if your PSU doesn't have a 6-pin PCI-E connector)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
ive had a build with a 6700k and a 780ti it got to 375
Just looked on Newegg I was wron it requires 400w psu
3 minutes ago, Thomas Reed said:
450W would be more than enough. A GTX 1080 and I7 6700k could get away if they weren`t overclocked, but definetly a 550W PSU. Seems like it should be more than enough, although I would reccomend waiting for the GTX 1050 or getting a GTX 950 on sale. If those seem like too much of a price go for an AMD card, RX 460 or 470 will have simmilar performene to the Nvida ones.
I checked on amazon , it says i have to "Global import" it. and there are 3 different versions with varying prices , am confused :(
2 minutes ago, TheRandomness said:
It doesn't. The required PSU thing is always waaay too much, 350W is more than enough.
Just listing the recommended spec to quote jay I digress.
2 minutes ago, Thomas Reed said:
Where are you from?
Does the amazon link have .com or .co.uk
asia
Car manufacturers recommend to run you car with a certain weight of oil but it will run with no oil just not for very long.
So i checked the rx 460 and it sits almost outside my budget , do you know anything about its 6 pin external power supply ?  can i use those molex to 6-pin to power it up ?
and can i use it with my old pci x16 Graphics slot ?
Any suggestions are always welcome :):)
