razer blade or razer badel sleath
why are people still looking at those shitty laptop's.
1. They all thermal throttle, that is not good. You loose at lot of performance and it gets so hot that it shortens the laptops life spand, by a lot.
2. They are loud really loud. 60dB
3. Build like cheap kids toys, it does not matter if you build the case out of titanium, but then use cheap screws and cheap glue to keep it together. Build quality is way more than just the feel of a laptop. Many idiots on YouTube and in real life only look at the feel when they talk build quality, but that just tells me that they know jack shit about build quality.
4. No quality control, so you might get one that has a dead USB port or a dead keyboard or maybe it doesn't want to turn on.
5. "Support", one word: Useless.
6. The keyboard, that thing feels like a keyboard that you should get on a 600$ laptop.
All of the razer blades are jokes and if we want to change this, then don't buy them, that is the only way. We as a consumer has a lot more power than you might think.
let us just get some more people in here, that knows what they talk about.
