Totally amazing and not dangerous cooling idea
PilotTroll
If you made an air tight pc case and made it into a make-shift vacuum chamber, would that cool a pc really well and will it blow up? (i kinda wanna try it but i have no idea what I'm doing)
wtf that would be the worst cooling case possible. there would be no where for the heat to dissipate and it would just stay on the component. even if you ripped off the heat sink and heat spreader it would have better cooling than being inside a vacuum because it can still transfer heat to the air
Yeah the way heatsinks work is by removing heat using air. No air = no cooling.
Gaming - Ryzen 5800X3D | 64GB 3200mhz  MSI 6900 XT Mini-ITX SFF Build
Home Server (Unraid OS) - Ryzen 2700x | 48GB 3200mhz |  EVGA 1060 6GB | 6TB SSD Cache [3x2TB] 66TB HDD [11x6TB]
1 minute ago, PilotTroll said:
but like... how do they cool shit in space?
oh shet
Shipping sucks
*read title* *came expecting some crazy s**t* was not disappointed.
Airtight case and vacuum don't mix, the case would just give in.
Not to mention it would get hotter than Linus in there
isn't space negative temps
Shipping sucks
temps sure but temperature does not equal heat
right however if you place a computer in a negative temp zone it will do 1000x better than say, texas lmfao
Shipping sucks
guys... how the f*** is the super computer on the iss cooled? that shits gonna get hot
big radiators and the heat gets transferred away through the object emitting infrared light
Just put a bag of ice on top of your pc and call it a day. 10/10 cooling
"Always forgive your enemies, but never forget their names." John F. Kennedy
"Daddy is going on a dangerous mission to shoot his employees." Linus Sebastian
"It's soft, but in a good way, kinda like typing on boobs." Luke Lafreniere
actually probably not. a computer in the air in the middle of a desert will probably cool better than a computer in space
probably a lot of the heat is reused in heating up water for astronauts and stuff
so, what you're saying is i should use my pc as my heating system? How do i do that?
it wont make it cool any better but you can actually use your computer as a heater by just having it run some intensive task
the outer space has a temp of −270.45 °C and it's so vast that the ISS isn't even worth a grain of sand
we are getting off topic... how do i get the heat away from my pc quickly and keep it cool because it doesnt like being hot.
Things cool in space by radiation. Radiation is far less effective than conduction.
There are things designed for cooling PC's called heatsinks and fans.
Things have been pretty on topic--you never asked about how to cool your pc in the first place.
It's called watercooling.
yeah, one came with my cpu, but it dont work too well... if i try to run too many things it gets hot as f*** and shuts down, its that fx-6300 cpu
